Old 02-17-2005, 10:01 AM   #1
oj70chevy
250 V-6 Club
oj70chevy's Avatar
oil sending unit? Please HELP
I have a 70 c/10 with a 6 cyl all is original including the dummy lights . I managed to get a set of gauges,front and under the dash harness for my truck but the problem I am running into is when it comes to the oil and temp sender. I found the temp sender for the 250 6cyl but the oil sender with gauge on the 250 is a single wire unit and the gauge has the hole in the back for the oil line. does any one have any info that could help me
Ralph
oj70chevy is offline   Reply With Quote
Old 02-17-2005, 12:40 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
If I understand this, you are converting from light to gauge?If your gauge is a "manual" simply remove the oil sender and replace with a line kit.
sneakysnake is offline   Reply With Quote
Old 02-17-2005, 12:46 PM   #3
oj70chevy
250 V-6 Club
oj70chevy's Avatar
Do you know if they make a manual sending unit for the 250 6 cyl?
Ralph
Old 02-17-2005, 12:56 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Ralph
There is no sending unit with the stock oil pressure guage. You simply have a copper or nylon tube with fittings on each end. One fitting screws into the block where your sending unit is now, the other screws in back if the guage. Very low tech
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 02-17-2005, 02:16 PM   #5
mrein3
mrein3's Avatar
Very low tech and very messy if it breaks.
It never has happend to me (knock on wood) but a friend had his oil line break inside the passenger compartment.
Think about it. Whatever psi your pump is pushing out is spraying in the cabin.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 02-17-2005, 02:23 PM   #6
oj70chevy
250 V-6 Club
oj70chevy's Avatar
Would you recomend copper or plastic for the line?
Old 02-17-2005, 03:10 PM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
I used the nylon line without any problems though I suppose most would recommend copper. As long as yoy don't route it across a hot manifold it should be fine. You'll also need the proper fittings (2). It should look similar to this Weatherhead® SAE 45° Flare Fitting below
Old 02-17-2005, 05:01 PM   #8
JJR
JJR's Avatar
You should be able to find line kits (Nylon or Copper) at your local parts store (or on-line if you can't find any local). They should run between $5-$9 depending on which type you get. I have had both types and luckily have never had a failure of either. The nylon kits are easier to work with and since you have straight 6, the oil line will mount on the passenger side of the block so the exhaust won't come into play.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 02-17-2005, 05:41 PM   #9
oj70chevy
250 V-6 Club
oj70chevy's Avatar
Thank you for the help.
Ralph
