02-17-2005, 12:33 PM | #1 |
OBS guy
Getting steering knuckles off D44?
Ran a search, most of the info was for 2bys. I was under the impression that the ball joints would have to be removed before the steering knuckle could be removed. Now it sounds like I can remove the knuckles with the ball joints in place?
I haven't gotten under it yet to really take a look, and I have never changed ball joints on a solid axle (upper/lower control arms only). I am sure someone has done this. I already have Moog M2 Uppers/Lowers on the way. I would much rather take the knuckles to a shop for the press work. Thanks...
88 Suburban Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear, Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more Last edited by redz 1970 K5; 02-17-2005 at 01:07 PM. |
02-17-2005, 06:18 PM | #2 |
The ball joints come off with the knuckle.
Tim |
02-17-2005, 10:01 PM | #3 |
If I remember correctly, the lower has a castle nut and cotter key, the upper has a nut and also a snap ring on the outside of the knuckle. The lower may also. Don't remember. Remove the nuts and the knuckle comes up and off.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
02-18-2005, 07:58 AM | #4 | |
The knuckle/ball joint assembly goes down to come off. There is a snap ring inside the knuckle on the upper ball joint (maybe sometimes the lower one has one too). The snap ring only needs to come off the separate the ball joint from the knuckle. The ball joints are primarily held be a press fit into the knuckle (from the top down).
Tim |
02-18-2005, 08:19 PM | #5 |
He is wanting to remove the ball joints so regardless of up or down, remove the nuts to remove the knuckle and then proceed from there. I am doing this tomorrow and the front end is on the stands. Just could not remember here in the house if it was right side up or not. Guess I will know this for sure in the morning. Good luck.
02-18-2005, 09:15 PM | #6 |
user # 2756
reminder leave one of the balljoint nuts on a thread or two when seperating the steering knuckle from axle, don't want it to land in your lap. I'm going to assume the spindles are off and the axleshafts have been removed from the axle?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
