Old 02-17-2005, 02:06 PM   #1
53burb
53burb's Avatar
rearend
Are the rears from the 60-66 body style the same as the ones from 67-70, assuming they are coil spring rear? A friend is going to look at a junkyard this weekend, and I want to see if I can broaden his search to include these for my Burb.
53burb is offline   Reply With Quote
Old 02-17-2005, 04:03 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
You need to take a tape measure and check the distance between drum faces so you get the right width. Measuring between the backing plates doesn't always work, some have different width brake shoes and wider drums.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 02-17-2005, 11:16 PM   #3
badpeanut
Not a bad nut after all..
badpeanut's Avatar
The '62 and older rearends are not Dana 44s or 12-bolts like the newer trucks (I'm talking 1/2-tons). They have a seperate nose piece rather than having a one-piece cast iron center section. They look like they'd be difficult to find parts for. Anybody know what to call these?
badpeanut is offline   Reply With Quote
Old 02-17-2005, 11:33 PM   #4
Americanrider
Are you talking about the Eaton rears?
Americanrider is offline   Reply With Quote
Old 02-17-2005, 11:59 PM   #5
72402
rearend
I'm pretty sure they are the same from 63-70 except the 63 & 64 had a longer panhard rod that hooked to a bracket on the right axle tube instead of the center section. Frank
72402 is offline   Reply With Quote
Old 02-18-2005, 12:45 AM   #6
1969 GMC
1969 GMC's Avatar
they are similar, but are 6 lug and semifloat. I don't know if it has the same size gears or not, either.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-18-2005, 01:16 PM   #7
53burb
53burb's Avatar
So does anybody know for certain if a 63-66 12bolt 1/2ton coil spring rear would be a simple bolt on to a '69 Burb, provided I find one I am satisfied with??
