Old 02-17-2005, 03:09 PM   #1
Chevy Muscle
< 69 Blazer
Chevy Muscle's Avatar
How much longer than stock are these shacles (front leaf)? - Pic
below is a picture.
I'm trying to figure out how much these shacles are adding to the lift of the front end. If you have stock shacles still, please measure them and let me know how long (either holes on-center or end to end)
Chevy Muscle is offline   Reply With Quote
Old 02-17-2005, 03:20 PM   #2
Big J
Its lookin' like a Blazer!
Big J's Avatar
Just guessing but they look to be a couple inches longer than my stock ones. If you lift the rear of the spring like that won't it affect your driveshaft angle and your steering? Looks like a good cheap way to gain a bit of lift. I won't be around my blazer till Saturday. If no one has measured for ya by then, I'll measure mine and post it for ya. Good luck!!
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 02-17-2005, 04:21 PM   #3
Chevy Muscle
< 69 Blazer
Yeah, that is what I was thinking too. This was done by one of the POs..... you should see the missmatch springs that were on it before I changed'em out.
Ok, I'll post a picture.... just toooo funny. The ones on the left were what I took off.
Old 02-17-2005, 05:09 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I'm not positive, but I think the stock shackels go up, not down. I'm at work now, but if I get a chance to run out to the parking lot, I can take a look at my Blazer and see.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-17-2005, 07:02 PM   #5
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here's a crappy pic of my stock shackles.
There about 5".5" long,end to end.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 02-17-2005, 07:07 PM   #6
Chevy Muscle
< 69 Blazer
Ok, that means mine are about 1" longer than stock.
Old 02-17-2005, 08:40 PM   #7
bouncytruck
SKINNY TIRES RULE!
I guess I was wrong. Maybe I'm thinking about the rear shackels?
bouncytruck 1972 K5
Old 02-17-2005, 10:40 PM   #8
aztxk5
Stock shackles are 4" center to center. Most folks won't run over 1" extended because it throws your driveline out the wrong direction. That's my.02 cents worth.
Al
aztxk5 is offline   Reply With Quote
Old 02-17-2005, 10:56 PM   #9
Lucasj03
4" c to c is correct for stock shackles. I have 6 1/2" shackles on mine with a 2 degree shim on the bottom of the leaf pack. The shackle gives a 1 1/4 of lift from stock. The lift is only half of the difference because your only lifting one side of the spring.
Lucasj03 is offline   Reply With Quote
