Old 02-17-2005, 04:22 PM   #1
1-PU70
1-PU70's Avatar
Need Info From 72 Service Manual
In the back of the book there is a page with Distributor specs. I need some info for the 402 or the 400 at the bottom of the page.
1 All the centerifugal advances, degrees and advance should be four
2 Vacume advance, degrees at HG should be two
3 Ignition timing, How many degress BTDC
Then on the engine page can you give me the compression ratio for the 402.
I have a 70 service manual but I have a 72 402 and want to see if there is any differance. Thanks Gary
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 02-17-2005, 07:56 PM   #2
1-PU70
1-PU70's Avatar
ttt
Old 02-17-2005, 08:07 PM   #3
dwaite72lnghrn
1. 0*@930rpm
2*@1260rpm
16*@2400rpm
30*@4400rpm
2. 0@8"hg
20*@17"hg
3. 8*BTDC
4. compression ratio 8.5:1
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 02-17-2005, 08:12 PM   #4
1-PU70
1-PU70's Avatar
