Life, Be In It.....
![]() Join Date: Oct 2003
How much horsepower will I get from this engine?
327 Large Journal Block .40 over Steal Crank TRW forged pistons 9.96 comp ratio Speed Pro Moly rings Michigan 77 rod and main bearing Edelbrock Proformer RPM cam and intake Pete Jackson noise gear drive World Torquer Heads Manley Swirl polishied 2.02/1.60 valves 67cc combustion chamber 3/8 studs Comp Cam roller tip rockers and lifters Edelbrock 750 cfm carb. 350 turbo street/street transmissions
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
68cst_ss490
I got about 410 horse at 5500 rpm and 424 ft/lbs at 4500 rpm
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
#3 | |
Your UncleBen
![]() Join Date: Dec 2002
Do you have any specs on the cam?
What are the headflow numbers? What size runners? lata CHRIS Quote:
68 C10 shortbed -- Street/Strip ![]() |
Life, Be In It.....
The cam is a edelbrook performer rpm
.500 lift intake 221 cfm / exhaust 166 cfm .400 lift intake 205 cfm / exhaust 156 cfm
#5 | |
Your UncleBen
lata CHRIS
Life, Be In It.....
Basic Operating RPM Range: 1,500-6,500 RPM
Intake Duration 050 inch Lift: 234 Exhaust Duration 050 inch Lift: 244 Duration at 050 inch Lift: 234 int./244 exh. Advertised Intake Duration: 308 Advertised Exhaust Duration: 318 Advertised Duration: 308 int./318 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.488 Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 Valve Lift with Factory Rocker Arm Ratio: 0.488 int./0.510 exh. lift Lobe Separation (degrees): 112
Life, Be In It.....
ttt
Your UncleBen
Just a guess. Since I am not familar with your heads and how they flow and whatnot. But I would say it would easily make 375hp? Maybe more?
Would be a nicely stout engine most definetly. If you chose a different cam I think you could make more power. But if you are decided on the cam or already have it then that will have to do. My choice would be a Comp Cams Magnum 280H with .480 lift. That one works REAL good in my buddys Camaro that we built. Of course it is a 355, but never the less the power would be pretty similar. Camaro does 7.20s in the 1/8th now. VERY stout small block! Check it out... lata CHRIS
Your UncleBen
Just curious...But what rods are you going to use? If you are using some good rods you might be able to go with a larger cam and use that Upper RPM potential of the 327. Say something that goes from 2500-7500 rpm!??!
![]() lata CHRIS
#10 | |
Life, Be In It.....
Thanks for the info, I was hoping for about 350 horsepower and changing a cam is not a big deal.
< 69 Blazer
I can't figure out how a piston manufacture can list a compression ratio with a given piston while not knowing what combustion chamber the heads are, if the block's been 0-decked, and what head gasket you're using.
#12 | |
Your UncleBen
Ballpark ![]() lata CHRIS
