02-18-2005, 12:49 AM | #1 |
Divorced Tcase
What are some options on Divorced Tcases? I know Rockwell 221s were used in earlier chevy 4x4s, but what other options on there? can any tcase be converted into a divorced case? I have a far off project... just trying to do alittle learning before i get into it....
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
02-18-2005, 01:23 AM | #2 |
with enough time and effort, anything can be done. so yeah, you could turn any married tcase into a divorced one...but its just not worth it. a divorced NP205 from a Dodge or International will work just fine in a GM. Concerning the Rockwell, I used to have one in my truck, but it died. Parts are $$$ for it. The NP205 is too common and in most cases cheap to pass it up, and its plenty strong for just about any punishment you can give it.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
02-18-2005, 01:28 AM | #3 |
I found out by measuring that my '71 IHC TravelAll has the same inner frame width as my '71 K20. So, I'm confident that the brackets & overhead cradle of the TravelAll's divorced NP205 would bolt right up to my '71 K20 by drilling 4 holes, 2 on each side. Maybe only the height of the overhead cradle would hit sheetmetal above in my K20, which would be a problem. Or, I'd have to position the NP205 low in the frame so that it hangs down too low and ruins the crossover height. I'm contemplating a divorced NP205 should I choose a 6-speed tranny that doesn't have an adapter available to mate it to an NP205. So this is theory. I haven't done this... yet.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
02-18-2005, 01:44 AM | #4 |
Jon, are you taking the leap?
02-18-2005, 11:02 AM | #5 | |
02-18-2005, 11:12 AM | #6 |
user # 2756
The 205 from a dodge would be from 69-74 years.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
