Old 02-18-2005, 09:26 AM   #1
400ex
Wood bed material suggestion
I need to replace whats left of my wood bed. I was thinking of buying some 3/4" sheets of wood from Lowes, Home Depot,etc.. Im not getting regular plywood. I was thinking something along the lines of a harder wood to withstand the weather for a few more years after coating it with something like linseed oil. Then maybe using using a router to cut some valleys for the metal strips to lay in. This is just a daily beater, nothing special.
I just dont know what type of wood to use. What do you guys suggest?
James
400ex is offline   Reply With Quote
Old 02-18-2005, 09:52 AM   #2
Putter
More Cowbell....
Putter's Avatar
My only concern would be that if you get "Sheets" of wood (Like Birch, maple, etc...) that if you don't get the perfect sealer on there, it will start to seperate on you. Especially where you route the grooves for the metal strips. I would buy some solid wood boards (nothing layered) and mill them to your specs. That is the route that I went and could not be happier. Mine was red oak that we cut down to size. I will try adn find the link for you and you can see how it turned out.
EDIT: Here is the link to mine...
Morning Wood
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 02-18-2005, 12:02 PM   #3
farside847
farside847's Avatar
Just as an alternative... there is a guy on ebay selling wood kits
for $170 - already cut and grooved. I priced the wood and it
would cost me over $100 in oak to do it myself....
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 02-18-2005, 12:48 PM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
If you went the plywood route, it should be marine grade plywood. It can take the moisture.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 02-18-2005, 02:40 PM   #5
400ex
Putter- Nice looking wood strips. I thought about doing cutting my own, but the only problem is that I don't own many wood working tools - skilsaw, hammer, square thats about it.. Plus I don't have a lot of wood working experience.
farside - Never thought of ebay. I will look into it although I never bought anything over ebay.
daburb - Where would one find marine grade plywood? Have you had good luck with it weathering and not rotting?
Thanks for the great advice guys.. Always learning something.
James
Old 02-18-2005, 07:56 PM   #6
dwaite72lnghrn
I just put 2x6 and 2x8 pressure treated wood. the only cutting would be to length and where the wheel wells are. this would make the bed sit 3/4 inch higher than normal but for a beater it works. I didn't even route the 1/4" bead for the metal strips they just sit a little above the wood after you tighten it down. just 6 2"x8"x8' and 4 2"x4"x8' for a long bed and a couple of pounds of carriage bolts and nuts/washers. reuse the 6 bolts to hold it down to the frame.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 02-18-2005, 11:01 PM   #7
72 CustomCamper
huh ???
72 CustomCamper's Avatar
I had a 79 f@&d step side that needed a new floor. I had bought a few 5/4 inch x 6 inch deck boards that I was going to use but the truck fell apart before I could install the wood...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
