02-18-2005, 11:40 AM | #1 |
my 4bt cummins in a 70 super short 4x4. What do u guys think ?
02-18-2005, 12:09 PM | #2 |
looks like a good fit!!! go for it!
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
02-18-2005, 12:11 PM | #3 |
user # 2756
what size gears/tires you going to run? That looks great. A real stump puller!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
02-18-2005, 12:41 PM | #4 |
tire size
I first thought it had 4:11's but after looking a little closer they are 3:73's. I am going to run 35's because it's got the nv4500 5 spd trans . I still have to change out the tailshaft hsg & mainshaft to the gm unit then get the advance adapter plate to the np205 as time & money permits .
02-18-2005, 02:43 PM | #5 |
sweet!!
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
02-18-2005, 06:29 PM | #6 |
The LuvShack Garage
WICKED
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
02-18-2005, 07:48 PM | #7 |
Born To Lose Club
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
That is simply spectacular!!! Keep the progess pics coming!
Brian Smith - "Born To Lose" 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
02-19-2005, 09:49 PM | #8 |
I don't see an adapter plate of any kind between the trans and engine. What kind if bellhousing did you use? Did it bolt right up?
I know absolutely nothing about diesels myself but it looks like it will fit good. What's the hp and torque ratings on it?
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
02-20-2005, 12:29 AM | #9 |
In the last pic u can see the adapter plate . It has the smaller black plate bolted to it. I just used a dodge adapter & bellhousing from a 98 diesel pickup then bolted the nv4500 trans up to the adapter . Everything bolts up great. The HP is rated at 105 & the torque is 265 stock but I'm hoping to get maybe 150-175 hp & 350 lbft of torque. I"m also hoping for 28-32 mpg out on the road .
02-20-2005, 12:43 AM | #10 |
This is definately a project I want to keep watching. I worry about the weight of that in the stock front end, are you going to do something with that?
02-20-2005, 01:37 AM | #11 |
any dodge with a diesel and a 5-speed will work. the 6bt and the 4bt should be the same
-1971 K20 350/sm465 -2004 1500 |
02-20-2005, 09:30 PM | #12 |
weight
The weight is not an issue . The 4bt weighs really close to the same as an inline 6 cyl gas (approx 700 lbs). I have so much room either to move the motor forward or back which is good but now I have to purchase the turbo & the turbo exh housing (down pipe) so I can see how far back I can place the motor to the body . The exh sys is I think 4" so I need to leave enough room for the pipe. One step at a time as $$ permits .
02-20-2005, 10:37 PM | #13 |
sweet !!will be one neat ride when your done. good luck also.
every man must believe in something, i believe ill have another beer! |
02-21-2005, 04:22 AM | #14 |
That's a cool swap! I thought about doing the same on my 68 K10. I was looking for a diesel frito-lay van with a 4spd. Pretty close as you can get for bolt in. They use the sm465 but the engine is tilted about 45 degrees.Not much luck finding any used ones around where I live. Good luck,looks really good.
68 K-10,79 K-10,80 C-30 57 chevy convertible 79 Z28 |
02-21-2005, 11:49 AM | #15 |
For sure it will be different.....
02-22-2005, 05:33 PM | #16 |
That is neat..............I am getting ready to put a 6AT3.4 Cummins in mine. I wanted to go with a 5.9 but I didn't want to hack my firewall up to make it fit. I am hoping for good fuel mileage too
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
02-22-2005, 07:39 PM | #17 |
I am thinking about this very swap for a future project. I can't wait to see it completed and running.
03-12-2005, 03:47 AM | #18 |
Here is what I have been looking for to do a swap. $100 bucks! engine is 2 yrs. old. It has a sm465 & chevy bellhousing.Just too far away from me!
http://cgi.ebay.com/ebaymotors/ws/eB...535098527&rd=1
03-14-2005, 02:14 AM | #19 |
4bt
over 1500 now still a decent buy if you need one Mike
hav'n fun be'n me |
03-17-2005, 07:51 AM | #20 |
ttt
Are there any updates on this project ?
03-17-2005, 06:32 PM | #21 |
4bt
Moneys tight (again) and the backyard is really muddy so I havn't done too much . I did buy the exh manifold and now need to get the turbo so I can see how close I can put the motor to the firewall. I will need to get a different oil filter head too the one I have mounts the filter vertically , I need one thats horizontally you can see it in the first pic. Oh yea I did buy a 1975 blazer gas tank w/ the brush guard , straps, filler neck for $50.00 . Slowly but surly maybe it'll be running this summer !
