Old 02-18-2005, 02:10 PM   #1
ezernut9mm
ezernut9mm's Avatar
finally, some pic's
well, the sun was shining so i thought i'd snap some photos. hope they're not too big...
uh oh. that's gonna have to be fixed.
where do i put my stuff?
hope that crack doesn't get any worse.
side note. can anyone tell me what that bracket is for? there's one on the other side too.
'06 silverado (daily driver)
'02 nissan sentra (wal-mart warrior)
ezernut9mm is offline   Reply With Quote
Old 02-18-2005, 02:15 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Look here
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 02-18-2005, 02:15 PM   #3
ezernut9mm
ezernut9mm's Avatar
anyone interested in drop bumper? that's gotta go.
this picture actually makes that wheel look good. it's outta there too.
those valve covers have got to go also. anyone have any stockers???
Old 02-18-2005, 02:20 PM   #4
ezernut9mm
ezernut9mm's Avatar
Originally Posted by CPNE
thanks!
Old 02-18-2005, 02:26 PM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
If the seat in that thing is original to the truck, what's it look like? It appears to have a seat cover over it.
Old 02-18-2005, 02:31 PM   #6
ezernut9mm
ezernut9mm's Avatar
i haven't pulled it off to look. from what i can tell it is white so i'm guessing it is not the original covering. plus it is broken down pretty bad.
Old 02-18-2005, 02:35 PM   #7
70c10
67-72 Addict!
70c10's Avatar
Nice color!.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-18-2005, 02:36 PM   #8
CPNE
Resident Curmudgeon
CPNE's Avatar
Well here's why I ask. In 72 Chevy introduced a mid-year trim package called the Highlander. Your truck has all the earmarks (tilt, auto,a/c, custom deluxe). If it's a highlander it will have a white vinyl seat with plaid cloth inserts. Your truck should also have white door panels and visors, with a black dash pad and black carpeting (if it's a highlander). I see the door panel is black, but it looks swapped out as it's not a custom deluxe panel anyway. Someone may have liked black better with the maroon repaint. So, tell me more about your seat
Old 02-18-2005, 02:38 PM   #9
ezernut9mm
ezernut9mm's Avatar
Originally Posted by 70c10
Nice color!.
thanks. if you look at the bottom of the fire wall in the last pic you can see that it used to be yellow. i'm not sure which one, but it was the lighter of the two shades.
Old 02-18-2005, 02:42 PM   #10
ezernut9mm
ezernut9mm's Avatar
ok. i haven't done much more than pull back the corners to peek underneath the cover, but from what i can tell from that and looking through the seatbelt cutouts in the cover you have hit the nail on the head. when it gets warmer out i will pull the cover and see what i really have.
Old 02-18-2005, 02:44 PM   #11
ezernut9mm
ezernut9mm's Avatar
i really wish the options sheet hadn't been painted over...
Old 02-18-2005, 02:45 PM   #12
CPNE
Resident Curmudgeon
CPNE's Avatar
Highlander Info here
Old 02-18-2005, 02:51 PM   #13
ezernut9mm
ezernut9mm's Avatar
the seat is indeed white and brown and seems to be in pretty good shape. i will pull the cover tomorrow to get a good look at it. the seat belts are white also.
Old 02-18-2005, 05:13 PM   #14
muddpile
muddpile's Avatar
So, are these Highlander things special or something? The reason I ask is because apparently I have one. Well, at least my interior indicates I do, I'll have to check the glove box tag, but my truck is a 72 custom deluxe longbox, orange and white with upper and lower trim and chrome trim around the windshield also. It has the chrome centers on all the dash knobs, black dash, and a white vinyl seat with yellow plaid inserts. The carpet is missing, so it may have been black. It is a 350 4 barrel with a 3 speed auto, AM radio, manual brakes and power steering (may have been added on by previous owner).
Can you buy replacement white door panels, arm rests and plaid seat covers for these trucks, or will I have to settle for houndstooth on the seat and black door panels. This old truck of mine might be an interesting resto after all
And ezernut, I must say that is one nice old chevy. I wish the one I'm starting with looked that good.
muddpile is offline   Reply With Quote
Old 02-18-2005, 05:21 PM   #15
RainFade
RainFade's Avatar
I might be interested in that drop bumper
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes.
My lame K20 page
My lame Eaton disc brake page
RainFade is offline   Reply With Quote
Old 02-18-2005, 08:30 PM   #16
ezernut9mm
ezernut9mm's Avatar
let me know if you want more pics. i might also be able to swing free shipping if you are close to an old dominion freight lines terminal.
