#1 | |
Bloo
milky oil on pcv valve?
i was checkign everything out on the 69, just outta boredom and need of maintnance... the pcv valve and inside the left valve cover under the pcv is covered in milky oil, but the oil pan is shiny black oil..... what could cause this?
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
Resident Curmudgeon
![]() Join Date: Dec 1999
If you have some milky stuff on the pvc, and are not losing coolant, and drive a lot of short trips in colder climates, this is perfectly normal.
If this is the case, it just means that your oill is not getting warm enough to burn off the excess condensation in the oil, or you need to replace the pvc valve
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#3 | |
Bloo
that would be it then, ive been driving it on 1/2 mile trips only for about a month now b/c of problems that make me not trust it to go to town. im planning to adjust the valves anyways so ill take the valve covers off and clean them and put in a new pcv valve i have here
#4 | |
~ Don ~ |
Ditto Head
A little bit of condensation is my guess.
