need info on "998" SBC heads
Anyone have information on heads with the last three numbers "998"? I am familiar with the "441, 882's" and a few others. These I know nothing about. Belong to a friend. Thanks
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
you mean 993 ? 993 are 350 heads, most have little valves, and are truck only heads in the early 70's, up, are heavy cast, no cracking problems, and are pretty common, great candidates for planing/milling and installing large valves and porting out and polishing up
Senior Moment
![]() Join Date: Mar 2002
Whats the whole # and have you looked at mortec.com ?
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Senior Moment
Fast could be right double check that # the 8 could be a 3. easy to misread
Thanks everyone. Fast, I don't know what they say on them. He is relaying the message to me and this is all I know. I will have him check again and then check Mortec. Thanks.
"See the U.S.A....."
The bad part about having all that machine work done is by the time its all over with youve spent enough money on them you could have just bought new ones from World ready to go!It just seams that machine work has gotten so expensive and the price of good aftermarket heads have come down.
1970 short bed fleetside 1949 all origional chevy 3600 1974 camaro Richmond , Texas(just S.W.of Houston) |
yeap yeap, you can get some iron eagles for 750 now.
I would be willing to bet that they are 993 and not 998 cause I made that same mistake on my set. make sure you check the valve sizes. a lot of the 993 heads came out with 1.94 intake and 1.50 exhaust valves. they are a heavy casting head and are one of the best for street performance on a 350. these were the heads that were used on all of the target master replacement engines. the ones on the target masters were made in mexico and have HENCHO EN MEXICO cast into them. the 1.94/1.50 valves will give you excellent street performance and low end torque. if you want to run high RPM's all of the time I might look for a set with 2.02 valves but if you overheat them they are prone to crack.
69 C-10, 340HP 327 55 chevy 4 door 150 47 Willys CJ-2A 05 Harley Night Train 06 1200 Sportster (Wife's bike) 70 Honda CL350 OIF2 & OIF7 Veteran ![]() Nathan & Tiffany |
| Bookmarks |
