02-18-2005, 09:43 PM | #1 |
question about dana 60 ff
Hi, I looked up my dana 60 rear axel on my 71 k20 pickup and it says full float. I've seen the terms full float and semi float in here but I was just wondering what float meant and how is semi verses full float differant. Thanks
02-18-2005, 10:48 PM | #2 |
huh ???
A full floater rear the weight of the truck rides on a spindle and 2 bearings per side like the front. The axel holds no weight. On a semi floater rear the weight of the truck rides on the axels and single bearings per side...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
02-19-2005, 10:31 PM | #3 |
user # 2756
break an axle on a semi floater and the wheel could come off. On a full floater the tire is mounted on a hub that rides ona a spindle like chuck said. full floaters have the giant hub that sticks out of the center of the rim.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
