02-19-2005, 01:06 AM | #1 |
Excelsior, You Fathead.
Turn Signal Lever Replacement
I am going to pull out my steering column to paint and repair it. Does anyone have the instuctions on assembly and repair so I can fix everything? Also, what is a cheap steering wheel that I can put in without havig to adapt parts.
Go Navy. The Sea Is Ours. Budget 350 Build http://67-72chevytrucks.com/vboard/s...38#post2264638 |
02-19-2005, 01:17 AM | #2 |
Steering Wheel
Almost every GM wheel up to Airbag (92?) will fit the spline and most horn contacts will work. Pick one you like the looks of and chances are it will work.
Good luck - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
02-19-2005, 07:57 AM | #3 |
its all about the +6 inches
And as far as the turn signal lever, once the wheel is off, you'll see a tiny phillips head screw holding the lever on.
