Old 02-19-2005, 08:17 PM   #1
RED72blazer
urban fourwheelin
RED72blazer's Avatar
who has hei in their truck
Has anyone install an hei in their blazer? I just dropped the engine into my truck and it looks like my distributor cap is touching the firewall. It is really tight in there and was wondering just how close everyone else's is. I hope I can get the cap off
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 02-19-2005, 08:24 PM   #2
EyeH8the24
EyeH8the24's Avatar
6 or 8
i have one that is hei and uses 6 cylider mounts and it is close to fire wall ..buti can get the cap on and off...the other usses v8 mounts...its a long way from the fire wall......
EyeH8the24 is offline   Reply With Quote
Old 02-19-2005, 08:35 PM   #3
Cethern
What was I thinking??
Cethern's Avatar
I have a HEI in my 71 and it is close but I can get the cap off..the hard part is getting the back hold downs turned to hold the cap.
72 K5 that needs lots of parts..
71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit...
Cethern is offline   Reply With Quote
Old 02-19-2005, 08:39 PM   #4
cnshoot
cnshoot's Avatar
i have heard of pepole moving the motor mounts up, It is something for you to get the extra room. you could use a hei top from msd that has the coil seprate this could help some
72 cst 2wd blazer sb soon to have tilt manual
72 gmc swb fleet 2wd bb air tilt auto
93 c/3500 crew-cab dually
03 chevy suburban LT quadrasteer c/2500 4x4
cnshoot is offline   Reply With Quote
Old 02-19-2005, 09:45 PM   #5
chucks70
Mine was touching the firewall when I first put it in. When I put new bodymounts on it no longer touches but is still close. I have heard of other people "adjusting" the firewall with a sledge. Another option, if you want more room is a body lift and as stated before, the remote coil type dist.
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible.
chucks70 is offline   Reply With Quote
Old 02-19-2005, 11:10 PM   #6
ktear
ktear's Avatar
I also just installed one in my Blazer. It's real close and it was real fun getting the cap & plugs on, but the cap isn't touching.. That's not to say that the 6 & 5 plug wire isn't though. It's tight, but I haven't had any issues and it starts real nice now..
70 Blazer - BDS 4" Lift, 33x12.50's. 307, 4bbl, HEI, Headers.
70 Z28 Camaro - Frame off restoration. 383, 700R4, 4:11 12-Bolt.
01 SS Camaro - SLP Bolt-on mods.
77 Monza - Drag car, ongoing project.
ktear is offline   Reply With Quote
Old 02-19-2005, 11:44 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I got one on my 350 in the blazer(K-5)and it is really close but no rubbin has been spotted..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-19-2005, 11:50 PM   #8
JBstor
JBstor's Avatar
I put one in my 70 Blazer when they first became popular at the wrecking yards (yeah I know, a LOOONG time ago) It fit, but just, I remember turning the rear hold downs with a long thin screwdriver, and the clearance was tight on the cap, I left off the top part that holds the wires, and that helped.
Since I had the engine out recently, I carefully hammered the firewall in a bit before the repaint. it looks good, but I havent had the distributor back in yet (a week away from that) It should all be good though.
JB
JBstor is offline   Reply With Quote
Old 02-20-2005, 08:15 AM   #9
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
count me in
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 02-20-2005, 11:17 AM   #10
moodyholler
moodyholler's Avatar
In for one year. Boots on wires touch firewall. No problems and driven daily. moodyholler
1998 WRANGLER I-6 auto
1972 LWB FLEETSIDE
1968 GMC SWB STEPSIDE
1994 C-1500 SWB 4.3 5 SPD
moodyholler is offline   Reply With Quote
Old 02-20-2005, 01:44 PM   #11
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
My '69 had HEI when I bought it. The cap has about a 1/4 inch clearance. One of the wire boots in the back touches the firewall. As mentioned above, the only problem is getting to the hold downs in the back - gotta have a short screw driver.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
