Old 02-19-2005, 09:14 PM   #1
Panelrodder
Panelrodder's Avatar
Weird Suspension/Vin #
This is the first thread that I've started and I've only had two or three other posts since I've joined so go easy on me. I have a lead on a 1966 Chevy that I want to buy but when I decoded the vin on a the only site I could find it couldn't tell me very much. Then number that I got off the registration was C15465119529 or C1546S119529. Can't read my writting right now!! The other question I have was the rear suspension is the trailing arm and coil spring setup but there is some additional springs "U" bolted to the frame that look like a set of Leaf springs that were cut in half. They are really really weird! Can someone shed some light on the Vin # and the extra leaf springs. It looks to me like it was something a farm just cut up and put together.
PanelRodder
Panelrodder is offline   Reply With Quote
Old 02-19-2005, 10:36 PM   #2
rodnok1
rodnok1's Avatar
If the springs are in back of the axle they are helper(overload) springs, and are common. You can find them for sale on 67-72 parts board all the time.
Vin decode from LMC catalog
C1546S119529
C=conventional
15= 1/2 ton
46(model type) is unlisted 4=pickup (could be 04=stepside, 34=fleetside)
S = st louis
119529=vehicle built number
Maybe somebody else can help with more details.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 02-19-2005, 10:55 PM   #3
apachetrucks
I agree with RODNOK1 the springs are helper springs and are not that uncommon on these trucks.The VIN number you posted is for a 1966 1/2 ton 2 wheel drive truck built in London,Canada if the 5th digit is in fact a 5.If the 5th digit is S then its St Louis.It was truck number 19529 built at that plant.Hope this helps!!
apachetrucks is offline   Reply With Quote
Old 02-20-2005, 01:53 PM   #4
Panelrodder
Thanks guys. Is there anyway to tell what engine and tranny came in the truck from the factory from the vin#? I'd like to know if the 75,XXX miles that are on the truck 283 small block and 3 on the tree are original or if it had something else in it. The kid that owns it now can't tell me. Thanks for the info on the helper springs. I didn't know that they made those for the coil spring type suspension.
PanelRodder
