Old 02-19-2005, 10:10 PM   #1
Peregrine
Peregrine's Avatar
Painting control arms
What's the best paint to use, and how?
Brian
72 C10 longbed 350/th400
Let the world change you and you will change the world.
Peregrine is offline   Reply With Quote
Old 02-19-2005, 10:28 PM   #2
rodnok1
rodnok1's Avatar
Hard part is getting them clean. I sandblast if rusty, clean them real good, heat them up in an oven to get rid of all residues then hit them with some rattle can Gloss black engine paint. They get nicked up during assembly but easily touched up, good enough for driver. I thought about trying the high heat paint for rotors and calipers that you bake on next time.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 02-19-2005, 10:45 PM   #3
COBALT
COBALT's Avatar
Take them to a machine shop and have them dipped and fired in a furnace. Then coat them with POR15, or take them to a coater.
I cleaned them with brushes I had on my power drill, and used brake cleaner, brushes, and a biodegradable detergent bath I could leave them in over night.
I tried rustoleum and hammerite. Rustoleum for the control arms, and other front-end parts, and hammerite on the sway bar.
The hammerite held up well on the sway bar, but the rustoleum was a disaster. If I did it over again I would have them professionally cleaned and coated.
One thing to remember is making sure that whoever presses in your lower ball joints does it in such a way to not tear up your coating or paint job.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
