Old 02-19-2005, 11:22 PM   #1
67cst
i love summertime
67cst's Avatar
can you put 3/4 ton 4x4 diffs and leafs on a 4x4 blazer?
just like the title says...are leafs on a 4x4 blazer and a 3/4 ton 4x4 truck the same in length? my dad has a 72 chevy truck that he wants to strip down and use the diffs and springs on a 72 blazer he might be purchasing..will this all work?
thanks, Derek
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 02-19-2005, 11:58 PM   #2
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
i don't see any issuee with tihs swap.....i recently did this with 87 c10 4x4 took 3/4 ton diffs and leafs out of a 77 put diffs and rear springs in the half ton bollted right up no issues should work for you as well.......best way to tell is to measure the springs.....diffs will bolt right up most of the time just need bigger u-bolts cuase the housing has a larger diameter
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 02-20-2005, 12:01 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I don't see any reason as to why this would not work..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-20-2005, 06:06 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
yep 69-72 are the same, 1/2 ton to 3/4 ton. on the 73s and up, some higher weight trucks had longer rear springs(56 v. 52) 69-72 have 52" rear springs. the fronts are different between the two generations though.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-20-2005, 05:21 PM   #5
Scrub
Collector of rusty Items
Scrub's Avatar
The Axles will bolt up fine however the springs are an unknown. When you buy a lift kit for a 69-72 chevy, they will ask the length of you rear springs as ther are two lengths posible. If you don't believe me, call Skyjacker. I think it might be 1/2 ton vs 3/4 ton that makes the difference.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 02-20-2005, 05:28 PM   #6
1FaastC10
1FaastC10's Avatar
with a 72, you wont be able to just bolt in the rear axle, you'll have to move the spring perches on the axles. or you could just find a 1 ton rear axle.
1FaastC10 is offline   Reply With Quote
Old 02-20-2005, 06:32 PM   #7
1969 GMC
1969 GMC's Avatar
No. Jim is correct.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-20-2005, 07:32 PM   #8
1FaastC10
1FaastC10's Avatar
what is the spring perch spacing on a 72 Blazer? i'm almost 100% positive that you cannot just bolt in a 3/4 ton axle, however you can bolt one in with a 73...
Old 02-20-2005, 10:08 PM   #9
ryanroo
ryanroo's Avatar
They are like 42 3/4" inches or something of the sort, blazers half tons and 3/4 ton 4x4 all had the same basic frame just adjusted for length, on a 72 the rear ends will swap without any trouble, i think, not sure but i think the u joint will be the same as well. as for swaping between generations, the spings are narrower on a 73+ for all trucks except the 1 ton, it is a strait swap for a 73+ one ton rear into a 67-72 truck or blazer 4x4. front axles have maintained the same pad width from 67 through the end of the strait axle trucks.
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 02-20-2005, 10:24 PM   #10
1FaastC10
1FaastC10's Avatar
Ryan
thanks for the confirmation on the Blazer being the same width as a 73+ 1 ton truck. you got your widths mixed up though the 1/2 and 3/4 tons are wider than the 1 tons by about 2"
Old 02-21-2005, 12:03 AM   #11
ryanroo
ryanroo's Avatar
No problem, i wasn't sure of the numbers, but now that you say that i remember. went through all of the same measuring and sh!t when i put the 60/14bolt in my 72 from a '80 tonner.
Ryan
72 K20 12v build
