Old 02-20-2005, 02:03 AM   #1
Twisted71c10
Twisted71c10's Avatar
FOR SALE: Complete pullout 350 from 71 camper special
i have a complete pullout 350 engine (air cleaner to oil pan) it needs rebuilt, but was running when pulled.
so if anybody is trying to restore a (i think it was a c10 or c20 camper special) this would be perfect.
trilogyz28@hotmail.com
Twisted71c10 is offline   Reply With Quote
Old 02-20-2005, 02:58 AM   #2
dtlilly
dtlilly's Avatar
Welcome to the board! I'm sure a camper special would be a 3/4 ton, but that doesn't make a difference in the engine. Listing engine numbers is helpfull so people can verify the year and application... engines have a way of being replaced over 25 years. The board requires a seller of parts to list asking price so a thread doesn't become an auction too.
dtlilly is offline   Reply With Quote
Old 02-20-2005, 04:08 AM   #3
Twisted71c10
it is the "original" engine, i'll get some numbers off it.
i didn't know what to ask for it?
i'll find out what it is worth and price it accordingly. sorry about that.
Old 02-20-2005, 04:11 AM   #4
Twisted71c10
#'s
left rear casting # 3970010
front right deck stamped # K09 03 TBA
Old 02-20-2005, 07:19 AM   #5
GMC AMI
GMC AMI's Avatar
engine #s
http://www.nastyz28.com/spmenu.html
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 02-20-2005, 07:52 AM   #6
3quartertime
My Mistress the Sea
3quartertime's Avatar
Casting Date
Small block casting date is located on driver side rear of block on flange forward of bellhousing. Big block on the right side of engine above the oil pan rails.
Casting Date Example: E038 - (E = Month, 03 = Day, 8 = Last digit of model year (1978)).
Month: A = Jan, B = Feb, C = Mar, D = Apr, E = May, F = Jun, G = July, H = Aug, I = Sep, J = Oct, K = Nov, L = Dec
#'s
Confused about these numbers. Casting # is used for many years. K is Nov. 09 is the day, TBA says either 70 or 71, but 03 doesn't seem to work for the year. Am I reading it wrong?
3quartertime is offline   Reply With Quote
Old 02-20-2005, 08:31 AM   #7
GMC AMI
GMC AMI's Avatar
Wink
Originally Posted by 3quartertime
Casting Date
#'s
K = Canadian block, 09= Sept., 03 is the 3rd day and TBA block code
Old 02-20-2005, 08:36 AM   #8
3quartertime
My Mistress the Sea
Thanks,
Learned something!!!
Old 02-20-2005, 08:39 AM   #9
GMC AMI
GMC AMI's Avatar
Question
I'm sure a camper special would be a 3/4 ton.
Hey relocated Reb, are you sure about all camper specials being 3/4 ton?
I have a 1/2 ton with 3 tanks and the camper hold downs and heavy duty coil springs. What would be the option # on glove box door? Thanks Man, stay warm. Has your blood thickened up yet?
Old 02-20-2005, 08:43 AM   #10
GMC AMI
GMC AMI's Avatar
Smile
Thanks,
Your'e
Glad I could help.
Old 02-20-2005, 11:50 AM   #11
jostrans68
Jostrans68
jostrans68's Avatar
I have a 68 that was a half ton camper special so they do exist in half ton my .02
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 02-20-2005, 12:16 PM   #12
dtlilly
dtlilly's Avatar
I have a 1/2 ton with 3 tanks and the camper hold downs and heavy duty coil springs. What would be the option # on glove box door?...
Option # Z81: Custom Camper; CE20 models with 350 or 400 engine only
with standard suspension. Available only when front stabilizer, optional shock absorbers and HD rear springs or auxiliary rear springs are ordered. Minimum tire requirements are 7.50-16/D tube type or 8.75-16.5/D tubeless tires..............................................................................................
With optional rear leaf type suspension. Available only when front stabilizer, HD front shock absorbers and HD rear springs are ordered.
KE20 models with 350 engine only. Available only when HD rear springs and optional shock absorbers are ordered. <tire info deleted>
KE30 models with 350 or 400 engine only. Available only when 9.50-16.5/D or 9.5-16.5/E tubeless or 7.50-16/e tube type tires, front stabilizer, HD shock absorbers, HD rear or auxiliary rear springs are ordered.
Chevy continues later on to state:
Recommended equipment on Chevy Pickup- Custom Camper requirments
Series C20 Custom Camper pickup or chassis-cab with standard rear suspension-- special custom camper nameplate; front stabilizer bar; 2750-lb. rear coil springs or 500-lb. auxiliary rear springs; heavy-duty rear shock absorbers; specify available 7.50-16/D tube type or 8.75-16.5/D tubeless tires or larger. (available leaf rear suspension is also rated at 2750 lbs)
Series CS/CE31003-04-34 (1 Ton) Custom Camper pickup or chassis-cab with single rear tires-- special Custom Camper nameplate; front stabilizer bar; heavy duty shock absorbers; 3,100-lb rear springs; specify available 9.50-16.5/D or 9.50-16.5/E tubeless tires, or 7.50-16/E tube tires.
Series CS/CE31403 (1 ton) Custom Camper chassis cab-- special Custom Camper nameplate; front stabilizer bar; heavy duty shock absorbers; 3,100-lb. rear springs; available dual rear wheel 7.00-16/C tires. (availablr rear axle is rated at 11,000 lbs.; 7.00-18/D tube type or 8-19.5/D tubeless tires are included.
Here's where I learned something!!!
Minimum equipement for shell or slide in camper bodies.
CE 10 Shell only
GVW rating-lb 5400
Ave. body wt. 700
Pass/Equip wt 1000
models CE10704
CE10734
CE10904
CE10934
engine stand. 307
transmission turbo hydro
rear axle capac 3500-lb.
rear axle ratio 373
front suspen. cap. 1450
front stabil -----
shock absorb. standard
rear suspension
capacity springs 2000-lb.
Aux spring-cap -------
shock absorbers standard
So... I was wrong, there were 1/2 ton trucks with Custom Camper. Please cook the crow before serving it please
Old 02-20-2005, 03:21 PM   #13
GMC AMI
GMC AMI's Avatar
Even cooked it taste like liver! Real dark and best eaten when served dished out cold
Like revenge! Lol. I was transplanted from SC so you are not alone Johnny reb.
Old 02-22-2005, 01:36 PM   #14
Twisted71c10
$450
pickup available in Indiana 47905
