Old 05-30-2002, 06:57 PM   #1
mikegi
Question driveshaft won't fit
went to put driveshaft in and found that front yoke has 31 splines and tranny has 26 whats the best thing to do.whole new driveshaft or new front yoke?it also has a hanging center bearing,never saw one of those.
Springvale,Maine
71 3/4 GMC lwb
mikegi is offline   Reply With Quote
Old 05-30-2002, 07:57 PM   #2
Mike C
Mike C's Avatar
There were two versions of the center bearing as you have discovered. Sounds like this was a heavy duty truck with TH400.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-30-2002, 09:55 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
what tranny you got ?
HD carrier bearings have side by side mounting bolts, light duty have in line mounting bolts, 4 speed and th400 normally use the HD version and three speed and th350- normally use light duty
i can cont some splines on some shafts i have around if you need, i have all kinds of different ones, PM me if so..
Fast68Chevy is offline   Reply With Quote
