Closed Thread
Old 02-20-2005, 02:05 PM   #1
Senator350
Senator350's Avatar
tire size to lift hieght ratio?
i'm running 6" suspension lift to clear 35" tires on my 70 k10 (converted to 1ton)
any of you guys running 44" tires might be able to help. i want to run 52" tires but don't really know how much lift i'll need.
any suggestions???
RN U OVR
Senator350 is offline
Old 02-20-2005, 02:09 PM   #2
uncle_handsome
Uncle H. is this cartoon
uncle_handsome's Avatar
Half the difference in diameter works out to 8.5", so I'd guess 8" minimum...
uncle_handsome is offline
Old 02-20-2005, 02:42 PM   #3
Mudder
Mudder's Avatar
You'll probably need a lot more than 8 inches for 52's or even 49's. I would plan on spending some very big bucks and doing things the right way if you're gonna tackle this.
Mudder is offline
Old 02-20-2005, 03:20 PM   #4
LONGHAIR
To go that tall you run off of the "normal" lift range.
It takes at least 12" to run 44s and 15" is better.
52s would require so much lift that you would probably not be able to connect the front driveshaft w/o some very serious modification. Meaning either "top loader" axles or at least a divorced transfer case to get it further back and down some too.
LONGHAIR is offline
Old 02-22-2005, 11:36 AM   #5
Senator350
Senator350's Avatar
i'm planning on a divorced case and to cut the differentials front and back to rotate them up for proper cv joint angles and rewelding them. i am thinking about 16" or 17"+ of lift, boiling down to 4" shackle flipped rear, 1" longer shackles and a custom 12" spring lift. will i have to move the front shckle locations for so much spring lift?
the dovorced case is a perfect idea with the addition of a cv joint on my rear shaft i won't need to lengthen in with this lift combo.
any thoughts on a 1" body lift? i know most people are against body lifts (mee too!) but 1" will let me weld on a prerunner style step bar without cutting the body. what do you think?
RN U OVR
Old 02-22-2005, 12:11 PM   #6
tnblazerk5
User #12137
tnblazerk5's Avatar
do you plan on going 4wheelin with this lift your talkin about ? and a 1 inch body lift would be ok . i also dont like body lifts either
tnblazerk5 is offline
Old 02-22-2005, 01:16 PM   #7
big70chevy
Tristan's monster truck!!
big70chevy's Avatar
I have a 12" suspension and a 3" body on mine to get it above the 44's. Since there is not a lift over 8"s offered for these year trucks you will need to have one custom made. And believe me, you are talking some serious $$$$. Even with the lift I have in my truck, I'm worrying about the tires front tires hitting once I get the big block down in it. Won't know until that day comes though. If you are very serious about the 52's, I know you can get a 16" set of springs made. Then again, there goes the pocket book. That would be the way to go though. Contact National Spring.
Good Luck!!!!!!!
1970 K20, 15" lift, 44" Boggers, 14" Weld Scorpios, 5.13 gears.
1993 K1500 ext. cab Z-71
1984 GMC C30 dump
big70chevy is offline
Old 02-22-2005, 05:27 PM   #8
Senator350
Senator350's Avatar
i've got a local spring shop that handles everything from toyotas to firetrucks. i highly recomend them Watkins spring in albany new york. they can do just about what ever it takes.
i'm running a sbc with a lot of weight relocation to the bed. i don't really want to cut but if i figure out the lift wrong that's what's going to happen, maybe even tub like the dragsters do. thanks for the help guys
RN U OVR
Old 02-22-2005, 09:43 PM   #9
1FaastC10
1FaastC10's Avatar
if you're going with 52s. get yourself a set of rockwells. 1 ton axles may have a hard time supporting 52s, your 1/2 ton axles will laugh as you attempt to bolt the tires to their flanges, and fall apart shortly thereafter.
1FaastC10 is offline
Old 02-23-2005, 10:28 AM   #10
Senator350
Senator350's Avatar
you must have missed when i wrote 70 k10 (converted to 1ton) i have a ff14bolt and 60 up front 410 copmlete 1350 HD shafts, i haven't really thought of rockwells, i know they're but i think they are a little overkill. you don't think beefed 1ton axles will handle an extra 50 or 70 lbs of rotating mass? what do you think will be the weakness?
RN U OVR
Old 02-23-2005, 10:56 AM   #11
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
probably not soo much as weight as the leverage caused by the taller tire. What are you going to re-gear too?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline
Old 02-23-2005, 12:07 PM   #12
Destructo
rockwells overkill with 52s? Nah, I don't think so haha.
I imagine 14B and D60 won't live up to 52s very long even with chromemoly shafts and all that good stuff. But then again I don't build to run in the mud, I build to run in the rocks, which that truck won't be doing since it will be WAY too tall to be running any trails haha.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline
Old 02-23-2005, 10:52 PM   #13
Senator350
Senator350's Avatar
jims70gmc, i'm not going to regear. the sm465 np205 combo are enough for me, it's not seeing any highway time so i don't need any speed over 30 or 40 mphs. the small block revs high enough that i don't see a need to regear, if anything i'll dual case and clock instead of divorcing.
as far as the leverage of taller tires i think the 20" rims will allow so little backspacing that it would likely even out.
destructo, why can't i run trails with it? fear of body damage? not me!! it's a longbed so i'm all ready familiar with wheeling with limitations. and besides, i don't mind rolling my truck... right over yours!! 52" will laugh at whatever rocks your struggling to stay on top of dude!
RN U OVR
Old 02-23-2005, 11:23 PM   #14
Gyva
Gyva's Avatar
I run 40 inch ground hawgs with a 6 inch superlift and 3 inch body, and I got bushwacker cut out fender flares. I have a 350/350 combo and I regeared my axles (gm 10 up front and Dana 60 posi rear, ya its half 3/4 ton half 1/2 ton) anyways I regeared them to 4.56 and even with only 40 inch hawgs I wish I would have went with 5.13 or lower. My get up and go is fair and I got a brand spankin new 350 in there, in the mud (2 wheel drive) my truck still bogs down starving for more gear or power.... so to have a set of 52's with no regearing is Crazy in my book... dude go with 6.something gears....... 52 is alot of tire.....
Mike...
Gyva is offline
Old 02-23-2005, 11:25 PM   #15
Super 71
I have 24'' of lift and its not to tall for my 52s and you might whant a bigger axle than a 1 ton if you plan on going off road at all becuase you will snap them like tooth picks.Already tride that! The 52s are almost twice as heavy as a 44. 350# each. Plan on $100 a inch per axle so 18''=$3600.00 + all the other stuff your going to need.
Super 71 is offline
Old 02-24-2005, 12:40 AM   #16
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Why would you need 52" tires? Wouldn't it be better to run less lift and a lot of trimming?
Either way, I want to see pictures!
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline
Old 02-24-2005, 12:43 AM   #17
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Reving high enough won't be the problem. I'm running SM465/NP205 w/ 35" tires and 4.56 gears and a mildly built 350. With the 4.10s you'll have your transfercase in 4 lo most of the time just to keep the engine rpms up. I just assumed you'd drop to 5.13s or lower. the 2.5 ton military axles have 6.71 gears.
Old 02-24-2005, 01:18 AM   #18
72gord
Never enough time!!
72gord's Avatar
I'm with Bouncy, I want to see some pictures of the 10 inch plus lifted trucks with the big rubber on them!!
72gord is offline
Old 02-24-2005, 02:08 AM   #19
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
What tires are yopu looking to get?
Any of these?
Old 02-24-2005, 02:53 AM   #20
low 84
low 84's Avatar
you didn't own anybody but yourself. you don't have a concept of what it takes to build a rock crawler. first of all you want a low center of gravity, with as much lift as you are going to run with 52's your cog will be way too high to rockcrawl, well unless you want to end up on your roof. 52 inch tires with 4.10 gears isn't going to give you enough torque multiplication to crawl over anything worth mentioning. springs with as much lift as you want will be so stiff your truck won't flex worth a crap. most rock crawling rigs run 6 inches of lift or less with around 40 inch tires, 4.56/4.88/5.13 gear, flexy suspensions, and lots of fender trimming for clearence
what your describing building wouldn't be worth anything in the rocks. mabey in the mud but you need some hp for that
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline
Old 02-24-2005, 03:01 AM   #21
1FaastC10
1FaastC10's Avatar
Ryan... you just described my truck! lol 6" lift, flexy suspension. 40s, 4.56s. i havent trimmed the fenders yet, but things are looking that way. right now the build is in a holding pattern.
i'd venture to say that Chad's truck, although stock, would give the monstrosity you're talking about building a real good run for the money.
Old 02-24-2005, 03:34 AM   #22
Destructo
4.10 gears, SM465, NP205, your gonna have to run in low range just on the street to move the truck! Nevermind what happens off-road!
Its gonna take that rig like a minute to get to 60mph if it will even reach 60mph.
Oh yeah, and I bet my stock suspension truck with 33x12.5" tires would probably out-wheel your truck on the trails
Old 02-24-2005, 04:08 AM   #23
Super 71
Is this truck for the rocks or the mud?
Super 71 is offline
Old 02-24-2005, 04:26 AM   #24
Destructo
I think its a safe bet it aint for the rocks with the amount of lift hes talking about, lol.
Old 02-24-2005, 06:15 AM   #25
1FaastC10
1FaastC10's Avatar
although he's talking like it will go anywhere. talk about a rude awakening.
Closed Thread
