Old 05-30-2002, 07:20 PM   #1
Suicide-D
Location: Katy, TX...but the love of my life resides in Dublin,OH.
patch panels
I am about to attempt to replace the floor boards, rockers and cab corners in my 71 1/2 ton. I know how to weld but am just wondering if there is anything I should be aware of before I screw something up. I have never welded in patch panels on a vehicle. I really could use the whole cab... to save time but I haven't found any that are better off than my own.
Thanks,
Darryl
Suicide-D is offline   Reply With Quote
Old 05-30-2002, 07:33 PM   #2
bigvinnie
bigvinnie's Avatar
best recommendation I can make is to spend the extra bucks on the GM panels vs. the cheap stuff, especially the rockers.... they fit much better and you'll save time and headaches... I assume you'll be using a MIG welder...??? only way to go for sheet metal... when doing rockers, leave the door on so you can measure to get the gap between door and rocker just right... good luck.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 05-30-2002, 07:43 PM   #3
Suicide-D
thanks for the advice bigvinnie. I do have a MIG and I will find out what the panels my local vendor was quoting... judging from the price... they probably are the cheap stuff...35 for floor pans and 18 for rockers 22 for the cab corners...
Thanks again
Old 05-31-2002, 07:51 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I used all cheapy panels when I did mine and had no problems. The best advice I can give is get yourself a spot weld cutter! These things work great!
There are alot of spot welds on the floor to brace that will need to be removed.
I replaced the rocker panel quite some time before the other work, then came back and did the driver floor and floor support as well as the outer floor that attaches to the rocker. There's nothing really hard about it. The nice thing is that most if not all the work can be done from the top.
Another useful tip is; cover any glass or other parts you don't want damaged by the welding spatter! I learned the hard way on another job I did. Weld spatters eat glass for lunch!
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 05-31-2002, 08:42 AM   #5
Randy70C-10
Randy70C-10's Avatar
I used JC Whitney panels and they worked great! Like bigvinnie said, do the rockers with the doors on and closed!!! You will never get them right otherwise. Once they are spot welded in place, remove the doors and finish. With the cab corners, I only used as much of the new panel that was needed to repair the bad area.
Randy70C-10 is offline   Reply With Quote
Old 05-31-2002, 10:32 AM   #6
ebfabman
If you like pics, here's a few
These are all import aftermarket parts. I found they are a little thicker than the original sheet matal and with some work, they fit well.
ebfabman is offline   Reply With Quote
