Old 02-20-2005, 10:27 PM   #1
Bubsco
Idle help - When AC is on truck dies
Looking for a little help.
I have my 350 with automatic idleing just right. When I turn the AC on, it drops about 200 and many times the truck dies. I hear that there was/is an original or after market option to solve the problem. Something to do with with either electric or vacuum signal to the carburetor that rasies the idle when the AC is on. I am currently runing a Holley 600. Will replace it to solve the problem.
I don;t really want to idle it fast to keep it runnig when the AC is on.
Anyone heard of the problem and how to solve it.
Bubsco is offline   Reply With Quote
Old 02-20-2005, 11:53 PM   #2
RainFade
RainFade's Avatar
You need an idle compensator selenoid, wired to the hot on the ac compressor clutch it'll kick up the idle when the compressor is engaged.
selenoid
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes.
My lame K20 page
My lame Eaton disc brake page
Last edited by RainFade; 02-20-2005 at 11:56 PM. Reason: hosed up link... removing
RainFade is offline   Reply With Quote
Old 02-20-2005, 11:57 PM   #3
72402
Quadrajets had a fast idle solenoid. Bracket mounted to the front of the carburetor. Power came from the compressor clutch circuit. When the compressor clutch kicked in, the solenoid pushed the throttle open a little to compensate for the extra load. You'd have to fabricate a bracket to put one on a Holley, but it should solve your problem.
72402 is offline   Reply With Quote
Old 02-20-2005, 11:58 PM   #4
72402
Dang, too slow.
Old 02-21-2005, 12:05 AM   #5
RainFade
RainFade's Avatar
Talking
Originally Posted by 72402
Dang, too slow.
But at least you can spell solenoid.... I need to step away from the computer and call it a day
My lame K20 page
Old 02-21-2005, 01:58 PM   #6
68speedalert
Semi-Senior Member
68speedalert's Avatar
Be a good idea to replace the Holley with a Q-jet or Edelbrock anyway. My history with the Holley 600 is not a good one.
Steve
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 02-28-2005, 08:47 PM   #7
Bubsco
Thanks for the help, I continue to hear about these Holley's, I'm going with the Edelbrock ...
