Old 02-20-2005, 10:57 PM   #1
SCOTI
SCOTI's Avatar
What did you get done this weekend?
Well, since Ken is on the road I thought I would get this going for him.
Sat. it was raining on/off & I was on call. I spent the day on/off @ work, but I did manage to make some progress on my stereo install in my 74. I got my door spacers mounted & 6.5" component speakers installed. I also mounted my 4x10's after sound insulating the somewhat modified brackets w/some sound deadening material used in motorhomes (kinda' like a cheap brown bread). I haven't decided whether I'm going to leave the spacers black (w/texture) or paint them tan to match the door panels/dash. I should have a new/GM/NOS dash sometime next week that I won off e-bay. Once it arrives, everything plastic gets a dye job so the inside will be looking decent soon enough.
Today I went by fellow board member Zeus' house & looked @ some 67-72 parts for my beater & RestoRod. I came home & watched the second 1/2 of the race & worked on laying out the cut lines for 'Z-ing' my spare frame for my RestoRod project (I haven't fully commited to cutting yet).
It was a nice day here in DFW so it was good to be out in the driveway.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-20-2005, 11:31 PM   #2
Russell
Professional Grade
Russell's Avatar
I got the Chevy's exhaust installed, and the GMC's engine installed. It is coming back out pretty quick though, found a 4l80e and a divorced transfercase to put into her Lucky for me, the engine is easy to pull, no body to get in the way, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-20-2005, 11:33 PM   #3
Moved the 82 from the bushes in the back yard out to the front yard for visibility. Tinkered with a few things on the daughter's Bonneville and my 96. Went to Monster Jam with the family Saturday night. Today, I did computer work. I'm off tomorrow, so I hope to get a lot of things done while the Kids are at school and wife is at work.
Old 02-20-2005, 11:36 PM   #4
SanitysBane
well i got the ground wire on my sub amp reconected after it gotpulled out when the amp went flying around under the seat when i got in my wreck and blew my wafer fuse in the process of reconecting it. and my EQ stoped crapping out on me. and plus i have a lead on a running SWB 83-87 truck that the body is in really good shape from what i've seen for 700 bucks. Looks like my project may start sooner than i thought it would
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 02-21-2005, 12:30 AM   #5
bagged_and_bodydrop
Just drag it
I got my gas doors, tail lights, and tail gate shaved, and started installing the 50 inch led break light strip in the shaved part of the tail gate. Started looking for a cool roll pan, with a tag in the middle and thats it. Hopefully get the cab completly in white sealer tomorrow, afer getting everything but the door handles and locks off.
bagged_and_bodydrop is offline   Reply With Quote
Old 02-21-2005, 12:42 AM   #6
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Installed a new battery...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 02-21-2005, 12:50 AM   #7
soleeagle
soleeagle's Avatar
Saturday I repaired the loose tilt column in my 91 burb and on Sunday I Installed disc brakes on the 14 bolt FF axle I am going to be putting in the burb.
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 02-21-2005, 01:07 AM   #8
low 84
low 84's Avatar
friday night i worked on the axles some more. the 14bff is painted, just waiting for my disk brackets and diff cover to get here so i can put the hubs back on and the axles in. got the d44 completly apart, those lower ball joints were a pita but it just took some coaxing from a bfh and a hot wrench and they poped loose.
i should be getting parts from three different places this week, 1/2" flange 1/4 plate diff covers from greatlakeoffroad as well as a set of their lazer cut rear disk brackets, shocks and brake lines and stabilizers, and something else should show up thurs or friday............hehe
few phone pics of the axle progress, notice the "custom" drivers steering knuckle that has a raised steering arm AND some sort of spacer block to raise the arm up even further. these axles came off a burban on 44's so i guess that was their attemp at correct steering geometry, lol. the block will be coming off of course
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 02-21-2005, 01:15 AM   #9
jordon johnson
got a new front licenses plate installed
lol....
94 cobra!!!!!!LOL
90 gmc 4x4 ext cab swb 355 6in lift
blue 85 4x4 lwb 350 4spd
red 87 1/2 ton 2wd lwb 305 th350
red83 1/2 ton 4wd lwb ---- 700r4
jordon johnson is offline   Reply With Quote
Old 02-21-2005, 01:29 AM   #10
ureckme
ureckmefixit2@cox.net
This week end I busted my ### shaving the holes in the bed rails, and doing all the body work on the bed of my truck. I got it primed, Then started the body work on the cab. Matt
ureckme is offline   Reply With Quote
Old 02-21-2005, 11:43 AM   #11
Hemikiller
Hemikiller's Avatar
Lessee...
on the '73 CCD..
Determined the 600DP had a pinholed power valve as the idle mixture screws did nothing. Changed the front hoping that was it, but it wasn't. Have to pop off the carb on Tuesday to do the rear.
Put in new plugs as the old ones were fuel fouled and 6 years old. Truck has Camaro headers and the two rear passenger plugs are such a PITA. I'll be putting proper truck headers on when I swap the '89 nose on. Had my balls broken by the HEI as usual. I hate those things. Going to get an MSD or something as soon as funds allow.
Actually got to drive it for the first time in years. No balls, as the HEI isn't advancing the timing. Other than that runs okay. Adjusted the clutch. Found all the parts I had taken off when I sent it to have the floors and rockers done. Have to bleed the brakes.
I did walk by the other trucks several times...
Wise man once told me; "Don't show me what you know, show me what you don't know"
Nothing worthwhile is ever easy
Present Stable:
73 C-30 CrewCab Dually 4X2
91 4X2 'burban
89 4X4 'burban
84 4x2 'burban (R.I.P.)
Hemikiller is offline   Reply With Quote
Old 02-21-2005, 12:54 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Saturday I spent assembling furniture for my daughters room. It was time for a Extreme Makeover to get all the little girl stuff out, and make room for some big girl things.
Like Scoti said, my weekend involved a road trip. Sunday Morning I got up and drove an hour to my bro-n-laws house to pick up the 700r4 that he built for me. Then I blasted off to Stoked Out Specialties in Rockwall. I spent some time talking with my buddy Keith, and checking out all the latest projects that they have in their shop. We unloaded the tranny and went to lunch. After lunch Roger showed up and we mapped out a plan for the transmission and I headed back to Houston.....
Thanks for starting the thread Scoti...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-21-2005, 03:07 PM   #13
SCOTI
SCOTI's Avatar
I tried to return your call but it wouldn't go through (I had some phone issues w/Keith earlier in the day as well).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-21-2005, 03:16 PM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
It could have been mine as well. I talked to Capt. Kaos on the way home and I dropped the call about 5 times. Call, PM or email when you have a minute so we can get back on track....
Old 02-21-2005, 06:07 PM   #15
1985K10
1985K10's Avatar
I went to replace the fuel pump in my K5 friday night, found out the gas tank was leakin. Saturday I ordered a new gas tank and straps for the K5, and installed a new booster and master cylinder in my Chevelle. Sunday I put in the new gas tank and fuel pump(and filter) in my Blazer.
Anthony
07 Tahoe LT
70 Chevelle 450HP 383-TH400
77 GMC Royal Sierra~Resto in progress~
1985K10 is offline   Reply With Quote
Old 02-22-2005, 03:50 PM   #16
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Stupid Verizon....
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-02-2014, 10:47 PM   #17
PcolaC10
PcolaC10's Avatar
Re: What did you get done this weekend?
New dash pad and painted my door panels to match.
PcolaC10 is offline   Reply With Quote
Old 09-03-2014, 02:53 AM   #18
y5mgisi
Second Chance Program
y5mgisi's Avatar
Sunday i built a cart for my new bed so i can push it in and out of the grage while i work on it.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 09-03-2014, 06:20 AM   #19
Your41Plague12
Your41Plague12's Avatar
This thread was going on 10 years old. Holy revival!
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 09-03-2014, 09:03 AM   #20
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Picked up a 7th trophy. 2nd place for Best Under Construction.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 09-03-2014, 09:17 AM   #21
SCOTI
SCOTI's Avatar
That's what I thought! Some of you guys are getting old
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-03-2014, 04:38 PM   #22
Old 09-03-2014, 08:21 PM   #23
bonuts
Got the truck dropped. Quickly learning why to never buy a northern truck, I will never do another truck with rust, a bit of a headache getting this truck up here but it is truly a rust free truck and I will save thousands in repairs. Could have done without finding three black widow spiders alive in it, but I will take spiders over rust any day.
1967 Chevy short stepside
1982 S-10
1975 C-10 2wd Short box
2014 Silverado
bonuts is offline   Reply With Quote
Old 09-03-2014, 10:32 PM   #24
knuckledragger
knuckledragger's Avatar
Saturday I replaced the valve stem seals on the wifes 84 gmc.When I pressured up the cylinders air was coming from the intake valley.I went ahead and finished the job and leak tested a couple of cylinders and found 40-60% leakage.Still smoked when done,rings are trash.Got pissed and started looking on clist for a plug and play engine.After several phone calls talked to a guy who didn't sound squirrely.Turns out he had put a crate motor in a customers truck and had the old one for sale.He advertised it as a 350 carb to oil pan.I went and looked and found it had new heads and looked like a very recent rebuild.It had a new edelbrock carb and intake and aluminum valvecovers.He threw in the starter and head pipes for the 350 manifolds.Got it home and saw the counter balanced balancer and decided to run the casting numbers.Yep! It's a 400.Installed it sunday and wow does it sound healthy.Has a rather large cam in it.Wish I knew more about it.The wife is very pleased with how it runs.Need to install a set of headers and see how it runs then.Feeling happy about my clist engine!Well spent weekend!
65 c-10 swb,bbw,step,402/t350,sold!!
1979 c10 Silverado,250,auto,gonna have a 3/5 drop,and twice pipes!Sold
Bought the wife a 84 gmc short step
knuckledragger is offline   Reply With Quote
Old 09-05-2014, 06:23 AM   #25
naphtali5725
naphtali5725's Avatar
drank too much tequila LOL
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
