Old 05-30-2002, 08:14 PM   #1
jrat
Low compression in first cyl
Im going to go check out this truck tommorow,what should I know about this low compression issue. Sorry im a tech idiot.
Is it somthing to be really concerned about? rings ? head? valves ?
72 GMC PU, <3/4>T, 350 4bbl, V8, reblt eng, 100,000 orig mi, orig owner, maint, new pts installed, have all rcpts for past 4 yrs, runs gd, low compression in first cyl
jrat is offline   Reply With Quote
Old 05-30-2002, 09:44 PM   #2
Longhorn Al
Texas Longhorn For Life
Longhorn Al's Avatar
My uncle and I found out one of my cylinders was missing. We took out that plug and hooked up a pressure guage. It was only putting out around 58psi.
He squirted some oil (not motor oil) into the cylinder. He said that if the pressure goes back up to normal, then it's the rings. If it stays the same, then it's the valves. Well, mine stayed the same. So I guess I just need a valve job. At least I don't have to tear apart the motor and replace rings!
The cylinder misses around idle, but it starts firing when I pick up speed and the compression builds.
1970 C-10 named HOSS
400SB/TH350, PS, PB, 3.07 gears
\m/ Hook 'Em from Austin, TEXAS
Longhorn Al is offline   Reply With Quote
Old 05-31-2002, 12:11 PM   #3
texnician01
texnician01's Avatar
yes you are correct. if you squirt oil into the cylinder and the compression does not get better then it is the valves. you can use any kind of oil, heck even tranny fluid will work. I would use something like a straight 30wt oil so it is good and thick.
Nathan
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
05 Harley Night Train
06 1200 Sportster (Wife's bike)
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
texnician01 is offline   Reply With Quote
