Old 02-21-2005, 02:15 AM   #1
john_doe
crossover pipe
I believe it's called a crossover pipe. It goes between the pipes on a dual exhaust system. I'm replacing my dual exhaust system and my current system doesn't have the crossover pipe. Should add one to the new system?
john_doe is offline   Reply With Quote
Old 02-21-2005, 04:16 AM   #2
Russell
Professional Grade
Russell's Avatar
Its well worth it
The pipe helps tone the exhaust down a bit, and helps with fuel economy. I plan to install an x-pipe onto my truck's exhaust system
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-21-2005, 01:07 PM   #3
barn9
Half a bubble off!
barn9's Avatar
Yes, you should add one, for several reasons. Engine pressure equalization and better sound being the main benefits.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
