![]() Join Date: Jan 2005
T-case rattles at 60 MPH...suggestions
It's a mutt (body from C20, frame and running gear from K20) 350 with 4 speed manual and I believe the 205 t-case. Shifts in and out of 4hi and 4low well.
When I approach 60 MPH the t-case shift lever starts to vibrate and make noise. Gets louder as I increase speed. Sounds like the linkage is rattling more than anything else. Suggestions? I can certainly live with this because the truck isn't my daily driver. Wondering if I've got a slight kink in a shaft causing a little wobble. Or bad bearing in the case?
'72 Chevy K-20 Crate 350, SM465, 4.10's |
Well When I approach 60mph in the 67 Everything in and on the truck starts to vibrate and make noise.
86 Silverado C10 back to 305 power! 67 C30 Dually Dump, with 350 transplant, Rockhauler 05 Duramax 3500 "If at first you don't succeed, try a bigger hammer" Member of the 1-Ton club! |
My shifter rattles too. I think a new shifter boot may hold it enough to keep it from rattling, but I am not sure. Let us know what you figure out.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
"Ochre Ogre"
I have the same thing. I know when I am doing 55mph by the rattle. The short term fix is to put something over it like a mitten, welding glove, heavy rag. I didn't believe it would work, but it does. Matt Rein told me this trick a few years ago and I have used it since.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
![]() Join Date: Feb 2003
I had the same prob with a 70 k20. PO use the wrong size bolt and no washers to hold the shifter. Replaced with correct bolt and washers and was tight as new.
Scott |
I was wondering about washers and bolts for the shifter. I'll check into that. Thanks. The boot is cracked and I can see the cement through it. Replacement coming as soon.
Yes, it is a 30+ year old truck, and it's going to rattle and shake. I'm amazed that it doesn't sound worse than it does...I'm thinking the PO took good care of this ride.
