Old 02-21-2005, 04:31 PM   #1
gotmud
gotmud's Avatar
tight ujoint
Bad news - Drive shaft fell out.
Good news - doesnt appear to be damaged.
I got a new rear u joint and installed it. But it appears to be really tight when I put it back on. Ive taken it off and done it again but cant seem to get it on to where it just flops around.
Any iders or suggestions from before?
Glenn
Glenn
Cumming, Ga
(68 C/10 Fleetside LWB 307
(64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty)
(2001 Porsche Boxster S - 168 MPH of fun)
(2005 Chevy Avalanche Z71 1500)
gotmud is offline   Reply With Quote
Old 02-21-2005, 08:36 PM   #2
rage'nrat638
rage'nrat638's Avatar
one of the bearings is not right....
rage'nrat638 is offline   Reply With Quote
Old 02-21-2005, 08:39 PM   #3
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Yup.make sure one of the needle bearings isn't laying in the bottom of the cap.Did that myself recently,being in a hurry doesn't pay off for me
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 02-21-2005, 08:48 PM   #4
69 longhorn
any little dent/ding will put the shaft out of balance....you might try seating the caps against the retainer rings (just thump the ends of the shaft with a lead hammer).....not on the tube tho!
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 02-22-2005, 12:35 AM   #5
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Is it the type of u-joint that the snap ring goes in a groove on the outside rather than the inside? If there isnt a needlebearing trapped in there some where & if it is the type that the snap ring goes in a groove on the outside then it may just be a tight fit. You can lightly sand the back of the cap that butts up against the snapring to increase clearance.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 02-22-2005, 02:26 AM   #6
Brainchild
Brainchild's Avatar
Could be the yoke is bent slightly,I hope not,but as you said it fell out.
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 02-22-2005, 02:26 AM   #7
ZOOMY
tight
The bearing cups are pressed too far in. Tap (hard) on the bearing retainer near where it's welded to the tube. (not the tube like stated earlier). Make sure you hammer at the correct indexing location. You want the bearing cups to be pushed back out a few thousandths. Not the cups that are in the differential yoke. The other pair.
ZOOMY is offline   Reply With Quote
Old 02-22-2005, 02:51 PM   #8
gotmud
gotmud's Avatar
Will look closer tonight.
Glenn
Cumming, Ga
Old 02-22-2005, 10:24 PM   #9
gotmud
gotmud's Avatar
It was a needle bearing issue. I replaced the whole unit and now she's running like she was new! Thanks for the response!
Glenn
Cumming, Ga
