C10 Club Tennessee
Recommendations on a 700r4 rebuild kit
As I posted this weekend I got a mechanic here in town who is going to give me a free 700r4. I would like to know what's a good rebuild kit to use. He told me he thinks it's from an early 80's car, but not for sure. I know that the later ones are better to have, but free is free. What kit can I get to make it better. Nothing special. I think it's a mechanical speedometer. He saw it and it has a hole on the driver's side of it. He said that some kind of switch goes there but he doesn't know what it is. Torque Converter comes with it. I have a TH400 as of right now.
thanks for the advice,
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
Your UncleBen
![]() Join Date: Dec 2002
Sell that one and buy one from these guys...Cost you more to rebuild it with GOOD parts than just buying from 700r4.com. Not to mention the early 80s 700s wheren't much and have alot of weak lengths in them.
Check them out. http://700r4.com/sitemap.shtml lata CHRIS
68 C10 shortbed -- Street/Strip ![]() |
s&l68 is right , I think 83 was the first year and the worst.
to make a 700r4 work right most trans guys use the case and replace the guts with 4L60E parts. The trans I need for a 502/502, prices have be 1500-2000$,but I think I'm going to talk to these guys there price was less than 1300$ Thanks for the sit info s&l 68
Pat ![]() ______________________ 1968 1 Ton Dually Flatbed 327/th400 1968 C30 Open Road 327/th400 1997 F350 CREWCAB 4X4 460 BIGBLOCK ![]() |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here is some info on id ing the 700 r4
http://www.highperformancecars.com/crosley/700id.htm VetteVet
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#5 | |
Your UncleBen
![]() Check this out...From 700r4.com... Behind engines above 450 hp and 450 ft/lbs of torque output, the input shaft to drum connection point becomes prone to fracture and the spline sun gear section will start ripping off the sun shell. Our level Three Transmissions have the following parts added for increased strength and reliability above 450 hp and 450 ft/lbs of torque. Reinforced input drum & sun shell for optimum strength with 30% larger fourth gear servo piston. These components are specifically engineered to help prevent breakage in applications with exceptionally stout motors. Experience has proven this engineering to be correct! lata CHRIS Here is a pic of that pesky part...
C10 Club Tennessee
Guys I don't have a high performance engine, it's just stock. All I want is something with overdrive and that gets better gas mileage. Nothing fancy. I thought someone had said one time that even though it was an older 700R4 I could upgrade the insides with certain kits.
C10 Club Tennessee
One thing I said I had a TH400 in the opening thread, sorry I only have 3 gears, so I guess that means I have a TH350----DUMBA$$
#8 | |
Your UncleBen
![]() lata CHRIS
#9 | |
Your UncleBen
lata CHRIS
C10 Club Tennessee
I'm going to go pick it up tomorrow I'll find out the year of if by looking at the stamp. My friend, the mechanic, doesn't know too much about tranny's he's just trying to clean out his place. He does have one out of a late 80's caprice he told me months ago he'd sell me for $25. The thing is that I talk to him the other day and he mentioned this one and I figured free is better.
I just helped a friend up here rebuild his 700R4, and he got his kit thru JCWhitney. It was NOT a high performance upgrade, just a stright rebuild. i think he paid $80. I thought the kit was ok, seals, clutch packs, new SS balls, springs, etc. The only thing the kit was missing that he purchased in addition, was the 2-4 band. He got a kevlar from a local tranny shop for $20 if I recall correctly.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
#12 | |
Your UncleBen
![]() lata CHRIS
