02-21-2005, 11:55 PM | #1 |
Where to put the air tank on the Blazer?
Where do you Blazer guys have your air tank(s). I wanted to put mine under the blazer, but with the gas tank and the rocker boxes there really isn't much room. Where do you guys have them? Pictures?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
02-24-2005, 03:36 AM | #2 |
67-72 parts collector,…
I don't have quick access to my Blazer,... but is there room "under" the rear seat for a tank? I think under the truck would be better. Like two small 3 gallon tanks, on each side of the gas tank. (outside of the frame rails). Only other choice is "behind" the rear seat. Has anyone done this to a BLAZER before?
02-24-2005, 03:37 AM | #3 |
Happy to be here
Mines an 82 so it's a bit different, but we put them beside the frame in the rear....
02-24-2005, 04:41 AM | #4 |
lolife99, there really isn't any "under" to under the seat. Only a few inches.
N2TRUX - is that a 3 gallon tank? I assume you have 1 on each side. I may be able to squeeze one under each side, I will have to go out and measure. PS - I was in the grocery store the other day in the magazine section, noticed your truck immediately. Great article - and nice shout out to the board
02-24-2005, 09:43 PM | #5 |
its just $$$$$
I had a 7 gallon underneath my 74. We mounted it inside the frame rail on the passenger side. I only had room because i was running a single exhaust instead of dual.
02-25-2005, 04:13 PM | #6 | |
Happy to be here
Thanks for the compliments. I figured since this forum is what got me the truck I better give it props... |
03-01-2005, 10:20 AM | #7 |
Got L.E.D.s
I have mine crosswise right where bed starts aluminum 4" diameter, they've been there awhile
Bagged 1972 2wd Blazer http://www.earlyclassic.com/home.aspx |
