bolt question ....
This question is for the bolt located in the front of the block near the timing cover on the lower passenger side. http://67-72chevytrucks.com/vboard/s....php3?t=138417 It is the bolt in the first pic . I am in the process of changing motors . The first motor that was in originally in the truck did not have this bolt , and there where no oil leaks . Why is this ?
BB or SB?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
did not have it, as in it was missing, just a hole where the bolt is suppossed to be, or just never was a bolt there?
72 GMC sierra 3/4 ton 402 bb ![]() 68 GMC 3/4 ton ![]() 2010 camaro rs: daily driver |
Still drivin' a Rat Rod
that bolt goes directly into an oil passage.If you read the post you linked to you will find that a long bolt inserted in there will hold the fuelpump rod in place while changing hte pump.Remove the longer bolt,replaqce with a short bolt and it stops the leaking.
Some one prolly changed th fuelpump,and forgot to put hte short bolt back in.I've done it myself
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
No there was not a bolt there at all . I bought the truck with that motor and ran it for awhile . Recently when I pulled it out , there was no bolt present
its all about the +6 inches
some of the engines were never drilled for that. Can't say why.
Well this one was drilled for it . It looks identical to the one in the picture .
That hole is not always drilled all the way into the fuel pump rod passage. Sometimes you have to put a long bolt in it & turn it all the way down with a wrench to break out the backside of the hole into the fuel pump cavity before you can use it to hold the push rod. It will then leak after you put the new pump on, so that's when you need the short bolt & some sealer.
