02-22-2005, 02:53 AM | #1 |
4x4 steering box question
Hello, I few months back someone stole my 86 Wrangler 4x4 and when I got the truck back, the PS box and pump was missing Is it possible to put a 2wd box from a factory 454 shortbox(77) into my Wrangler? Or will I have to find a 4x4 box? Thanks
02-22-2005, 02:59 AM | #2 |
2wd and 4wd boxes are not interchangable
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
02-22-2005, 03:18 AM | #3 |
A 2wd and 4wd are identical except for the sector shaft. All you need to do is switch out the sector shaft to make a 4wd box a 2wd box and vice versa. If you have a good deal on a 2wd box then go ahead and get it. Then just o to your local junkyard and pick up a sector shaft from a 4wd box and swap it in. Let me know if you need one. I may be able to find one for you fairly simple.
02-22-2005, 04:44 PM | #4 |
wow, another CK5 crossover. didnt even realize you were here esteban.
