02-22-2005, 01:39 PM | #1 |
Q for trucks with Blazer fuel cells?
Love the idea of putting a Blazer fuel cell under my frame and getting that potential fire-ball out of the cab.
But what do you do about a spare? Just throw it in the bed? Or mount somewhere (in bed? on front of truck...seen farmers who do that...thought it was pretty cool when I was a kid). Hmmmm... Does anyone make fuel cells that ride inside the frame rails and in front of the rear axle? I'm not a huge fan of the saddle bag cells.
'72 Chevy K-20 Crate 350, SM465, 4.10's |
02-22-2005, 02:26 PM | #2 |
Active Member
Mine went to the bed after my tank change,going to find a trick mount to set it on the side frame of the bed - lock it in place and then put a nice tire cover over it. Hanging one off the front bumper works as you see them all the time on as you said farmers rigs but something just bugs me about covering up the air flow to the radiator. As far as inside the frame gas tanks most all new trucks come with those and have for many years now so a careful search of the junk yards my turn up something you can use. I installed a 38gal tank in the rear frame out of a mid 80s Suburban along with the body fuel door which is now on the pass. side. HTH::::COBRO
02-22-2005, 02:30 PM | #3 |
67 is sold
I do not plan to run a spare tire once my truck is done.
I'll have a small 'space saver' type for road trips |
02-22-2005, 02:34 PM | #4 |
If I remember right you purchased a long bed.
There is a cool mod you can do, take a bed wheel well, and mount it upside down right in front of the wheel well, so it is sunk into the bed. It will drop the tire enough so it doesn't stick over the bed side, but it won't hang below the bed either. If you do it, be sure to put holes in the bottom to let water drain.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
02-22-2005, 03:32 PM | #5 |
senior member
[QUOTE=Daubs]Love the idea of putting a Blazer fuel cell under my frame and getting that potential fire-ball out of the cab. QUOTE]
dont mean to hijack your thread but i think ur more likely to get rearended than Tboned and start a fire just my .02
69 GMC bagged |
02-22-2005, 04:46 PM | #6 |
pissonNOS: yes, more likely to get rear-ended...but at least if that happens the bed's gonna fry...not me and the cab
02-22-2005, 05:07 PM | #7 | |
Resident Curmudgeon
Valid reasons for moving it IMO are leg room or additional stowage. If you smell gas, you probably have a bad o-ring around the sending unit or have over-filled the tank and it's sloshed out the filler. The real reason the tank was moved in 73 had nothing to do with safety...think factory crew cabs. Given the expense and inconvenience involved don't do it under the pretext of safety. They make Volvo's for that To address you question, from what I've read, most don't carry a spare, or toss it in the bed only on longer trips. There was an optional in-bed spare mount in these trucks which might address you needs.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
02-22-2005, 05:26 PM | #8 |
71swb4x4-
Do you have any pics of the modification you were talking about. Putting the spare somewhere like that might work pretty well. Thanks-
WWS!!!!! 1971 Custom C/20 1992 Chevrolet Z71 1993 Jeep Grand Cherokee 1984 Chevrolet Celebrity (All old but long ago paid for) |
02-22-2005, 05:42 PM | #9 |
I don't carry a spare. I guess I could for trips, but haven't. I'd also need my floorjack and a crossbow. I do like having the extra room in th cab, and with my later model bench seat, I like being able to tip the back of the seat forward to expose the stuff I keep back there.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
02-22-2005, 06:53 PM | #10 | |
The oddest Todd around
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
02-22-2005, 08:11 PM | #11 |
I kept a can of fix-a-flat in glove box. Haven't use it on the truck,but have seen it in action. Pay a few extra $$'s for the large can. Its works.
72 CHEYENNE 10 SUPER 468/400/3.73 |
02-22-2005, 08:16 PM | #12 |
02-22-2005, 08:42 PM | #13 |
Maybe you call it a 4 way? You know, the thing you use to remove and replace lug nuts when you're not by your shop with air tools.
02-22-2005, 09:00 PM | #14 | |
Resident Curmudgeon
02-22-2005, 09:14 PM | #15 |
if you don't wanna carry a spare, at least carry a can of fix-a-flat, and for more ammo, carry a small air comp. and a tire plug kit. if you are running air bags you could install a quick connect and a air hose to get ya out of a bind without carrying another air comp. i've seen pics of the recessed wheel well modification but i can't find the pics. it was inverted in the left front corner of the bed with a 1/2" hole drilled in the bottom to let water out. i'm gonna have this setup in mine and i want it to sit low enough to put a hardcover over.
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project |
02-22-2005, 10:14 PM | #16 |
Tucson ain't tough, yet. When you gettin' here?
02-22-2005, 10:35 PM | #17 |
Merciless Butcher
South Tucson is not a country club estate!
Your Bought And Sold....I Got Your Soul! |
02-23-2005, 08:48 AM | #18 | |
67 is sold
http://www.geocities.com/cst68chevy/sparetire.html |
02-23-2005, 09:06 AM | #19 |
Don't forget about the new space behind the seat....do-nut spare and jack.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
