Old 02-22-2005, 04:37 PM   #1
chevyfarmer
chevyfarmer's Avatar
Need Big Block Mounts
Hello,
I just found this place today and wow what a great resource! I can’t believe how many 67 – 72 gearheads are on line out here! As I mentioned in the title I am in need of a set of big block mounts, the ones that actually bolt to the frame. I am putting a 454 in my 2wd 72 blazer, with headers so I don’t think I need the specific 72 ones do I? Any replies to this will be greatly appreciated. I have the 3 bolt style mount that bolts to the block. I am trying to figure out how to post a picture as well. Thanks
chevyfarmer is offline   Reply With Quote
Old 02-22-2005, 04:53 PM   #2
jamie72
jamie72's Avatar
pm sent
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 02-22-2005, 05:01 PM   #3
boraxman
Keepin an eye out
boraxman's Avatar
Welcome to the board, youll always find what you need here!
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 02-22-2005, 05:12 PM   #4
Harry's 71 C-10
Welcome to the board. I sent you a PM
Harry's 71 C-10 is offline   Reply With Quote
Old 02-22-2005, 05:31 PM   #5
Joe67
67 is sold
Welcome
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 02-22-2005, 05:54 PM   #6
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Of course either style will work just fine...but, I recommend 72 MMs for your application. They may be a little stronger for that 454 and they are a little more correct for your 72.
Be sure you get the complete set with the engine brackets/cups on the 72 style.
I have both styles.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 02-23-2005, 12:18 PM   #7
chevyfarmer
thanks
Thanks to everyone who has replied to my post. Before I buy a set does anyone here know if the 68-71 styles will work in my 72 frame, yes I know they will work but I will be running headers, so the least mount of clearance issues the better. Any ideas are appreciated. Thanks again.
PICKMUP. Thanks for the pictures, are the top ones for a 72, and the bottoms for a 68 - 71?
Hopefully the picture will attach correctly, it shows it almost fitting with small block mounts.
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
Old 02-23-2005, 07:29 PM   #8
wannabeburbowner
wannabeburbowner's Avatar
The top pictures are the 72's bottom are 71 and down. I am not absolutely positive on this, but I think that all BBC mounts will get you the same clearance regardless of the year. 72's are a better design and a little stronger in my opinion, a little me pricey too. From what I have learned you cannot run SBC mounts at all with a BBC...no clearance for any header or exhaust manifold. I never heard anything about clearance differences between 72 and other year BBC mounts.
Later,
Travis
71 Chevy Long Bed (gettin' bagged)
84 GMC K1500 (Sold)
85 Monte Carlo SS white w/gray int. (being a dumba** and totaled it )
85 Monte Carlo SS clone T-top (Sold)
72 Chevelle-tubbed
64 Buick Sportwagon
wannabeburbowner is offline   Reply With Quote
Old 02-23-2005, 08:38 PM   #9
meathead95
computer illiterate
meathead95's Avatar
i have a nos set of 68-71 bbc mounts pm me if interested
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 02-23-2005, 11:09 PM   #10
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
The only problem with the 68-71 is the cost of the new rubber MMs. They are a good strong setup, but $$$$. The metal towers are more common, but used rubber MMs are not a good idea.
The ones in the bottom pic are complete with the new (4) rubber MMs & the towers. They cost more than the 72s because of the new parts.
I can sell them to you either way, if you need them.
Phone: 360-956-7170
