fuel injection who has it ?
i have a 383 stroker running the vortec heads. looking into switching over to fuel injection . who has a good system that will fit my engine without alot of crap to install ?
4x4k30 if trouble was money i would have plenty |
Professional Grade
There are lots of different EFI options out there. Tons of aftermarket setups made by companies like Edelbrock or Holley, and of course, the OEM EFI setups. Personally, I plan to run a tuned port fuel injection setup on my truck. I've got everything I need to install it, just gotta break my engine in first, and get the body back on the truck.
For a higher performance engine like a 383, you need something that is gonna be able to breath well enough for it. There are a couple different options. First is an aftermarket TBI setup, many of them flow extremely well, and are easy to install, and just generally good systems. If you want to go a bit more exotic, you can get yourself a tuned port setup, either aftermarket or OEM. If you decide to go OEM, you will need to replace the intake with something that flows a bit better. There are the aftermarket intakes such as the SuperRam intake, or you can buy an LT1 intake, send it to the fellow at LT1intake.com and get it machined to fit your small block. A stock intake will run out of breath at about 4800 rpm on a stock 350, it'll run out even sooner on a 383. An LT1 intake compares extremely well with all the other different intake options out there, but is much cheaper. Personally, when I upgrade my EFI setup, I plan to go the LT1 intake direction, it looks cleaner, and performs well beyond what my 355 will ever need.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Regular guy
I'm running Edelbrocks Pro-Flo MPI and so far I'm happy with it.
EFI is great! I've had the system for about 3 years and it was one of the only full systems out back then. Now there are a lot more options available. The new Holley Stealth Ram is really nice and isn't much more than the Edelbrock system. The Stealth Ram is programmed with a laptop and the Edelbrock has a little hand held program module. If you like to tinker with things the Stealth Ram and it's programming is the way to go. The Edelbrock is very limited in it's parameters. Look at the stock units also. Street and performance has some nice stock systems as well as these folks http://www.fuelinjection.com/
'Frank' 77 Silverado 18 & 20 American CL205s Edelbrock MPFI, 700r4, Baer Brakes 9" F@rd rear, Vintage air, Bags etc etc.. Last edited by 7T7; 02-22-2005 at 10:57 PM. |
Right on the line, baby!
I've also heard that the stock systems poop out around 4500 (for, say a 400 or 383). But I think you'll have to install a lot of crap regardless. As far as the crap: ECU, high pressure fuel pump, newer dizzy. I may have missed some things.
I'm thinking about throwing one in mine in about 2 years (It'll take that long to fill up the jar & 'til then let's just say it's not high on my list.) This might also be a good question for the "Engine & Drivetrain" list.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
Gentleman Jim Driver
I've got efi on my 84 K10. I'm using a GM Performance Parts Ramjet intake on a 355 I built about 6 years ago.
Take a look at this thread: http://207.44.196.117/vboard/showthread.php3?t=132300 I've also put a writeup on my web page.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
Ultimate Diesel Dude
I have mechanical fuel injection on my '81! It came stock with the diesel engine!
![]() Sorry, couldn't resist! ![]() Casey
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
I am building a EFI ITI system from a converted Hilborn setup for my BBC.
![]() For the simplest system you can't beat the TBI setup.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#8 | |
STILL PLAYS WITH TRUX
![]() Quote:
Im runnin' TPI on my truck but my eng. is stock. TPI can support a 383 but if you plan on running a large cam forget it you will never get it to run right or idle with out alot of high tech programming and tweaking and it sounds like you dont want to fool with it that much. |
#9 | |
TBI setup for about a 1G: http://www.customefis.com/pontiac.html There are a number of engine builders that make 383's for TBI setup. example: http://www.high-performance-engines.com/spc1.html If you are looking at making power over and above 350, then I agree, TBI isn't a good idea.
