Old 02-22-2005, 09:27 PM   #1
smitty62
smitty62's Avatar
Oxygen sensor thread?
I need to drill & tap an exhaust manifold for an oxygen sensor--does anyone know what thread these are? Thanks
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 02-22-2005, 09:31 PM   #2
gmc67swb
gmc67swb's Avatar
I believe 18mm
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 02-22-2005, 09:32 PM   #3
71swb4x4
71swb4x4's Avatar
I think they are metric
M18 x 1.50mm
Not positive, I googled it.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-22-2005, 09:34 PM   #4
71swb4x4
71swb4x4's Avatar
The Bosch LSU 4 sensor is a pump cell sensor like the NTK L1H1. The sensor requires a bung with an 18 mm diameter hole with 1.5 threads/mm pitch (this is one of the standard lambda sensor & sparkplug base sizes).
Here is some more support, everything I have found says 18mm x 1.5mm
Old 02-23-2005, 01:53 AM   #5
smitty62
smitty62's Avatar
Thanks guys! I believe 18 X 1.5 is correct. Now to find a tap??
Smitty
Old 02-23-2005, 07:56 AM   #6
EROC
Active Member
Drilling and tapping cast iron can be a real PITA. Your local muffler shop can probably sell you a steel oxygen sensor bung for a couple bucks. Just drill a hole in the pipe just past the manifold and weld the bung to the pipe. If you decide to get a tap most auto parts store sell taps to repair spark plug holes, which I think are 18mm.
69 GMC 2500 Camper Special
88 S10 Pickup
04 Impala
I ship UPS from 24153
EROC is offline   Reply With Quote
Old 02-23-2005, 08:07 AM   #7
tom hand
CCRider
tom hand's Avatar
http://www.needboost.com/part/holley..._sensor_bungs/
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 02-23-2005, 08:45 AM   #8
neonlarry
neonlarry's Avatar
You would be better off with a bung vs tapping unless you also want to machine a flat surface around the hole for the sensor to seal against.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 02-23-2005, 11:14 AM   #9
smitty62
smitty62's Avatar
Wow Tom!--$13 plus shipping for a 39 cent bung?? I don't think so! Those guys don't even use a gun!
The reason I wanted to tap it is that welding old cast iron (ramshorn) can be a disaster--even using TIG.. The bung don't expand/shrink at the same rate as the cast. It can last a year or so before cracking, but you've still lost a manifold. Thought I'd try tapping with welding as a last resort.
Smitty
Old 02-23-2005, 06:40 PM   #10
'70_402
'70_402's Avatar
You Can Go The Parts Store And Get A Spark Plug Anti-fouler And Cut It Apart And Use It For The Threads...thats What I Did....
'70_402 is offline   Reply With Quote
Old 02-23-2005, 08:10 PM   #11
krue
Designated A-hole!
krue's Avatar
I don't know jack about FI but couldn't you just put the sensor in the exhaust pipe instead of the manifold? Seems like it would be a heck of a lot easier.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-23-2005, 08:15 PM   #12
smokekiki
Mike
smokekiki's Avatar
Weld it into the exhaust pipe below the manifold.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 02-23-2005, 09:53 PM   #13
neonlarry
neonlarry's Avatar
^ Good sugestion if the sensor doesn't work right there, i.e. too cold use a heated sensor.
