02-23-2005, 01:56 AM | #1 |
dana 60 gears
I need a lower set of gears for the dana 60 in my longhorn.It has 4.10 gears now and i would like to find somthing way lower to get better gas mileage.Any suggustions or a ratio that we should use in it?any place to get the gears at?The truck is a 350 with a th350 trans and we are running 265/75-r16 tires on it.Thanks crystal
02-23-2005, 02:09 AM | #2 |
Young Gun wth Fast Inline
They have 3.54s made just for that. Will cost you the gears and a new carrier though.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
02-23-2005, 02:31 AM | #3 |
nope, your current carrier will work. the split is 4.10 and down, and 4.56 and up. just need the gears.
EDIT: I'm not sure if I'm reading your question right...lower gears would be 4.56's. But I don't see how that would get better mpg (except in town). If you want 4.56's, you need a new carrier. If you want higher gears, you are good to go on the carrier.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 02-23-2005 at 02:33 AM. |
02-23-2005, 04:13 AM | #4 |
they put 3.54s in some 3/4 ton burbs.
02-23-2005, 08:37 AM | #5 |
1969 GMC, she means lower number or a higher gear ratio. Crystal, IMO you should run at least 308's with your present set-up. The truck will most likely put the speedo needle in the p of the MPH at wide open, Gas mileage will improve.
1968 Chevy 4x4 307 4 speed |
02-23-2005, 10:59 AM | #6 |
user # 2756
big block c20s came with 3.54 rear gears in the dana 60s.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
