Old 02-23-2005, 02:25 AM   #1
skokie
skokie's Avatar
Oil on intake Bolt
I noticed this tonight. How did oil get around the intake manifold bolt?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 02-23-2005, 02:27 AM   #2
cableguy0
it came up through the threads. pull the bolt and put some thread sealer on it and the problem will go away its common with small block chevies
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-23-2005, 02:29 AM   #3
skokie
skokie's Avatar
Thanks cableguy0. I thought I had coated them all but I guess i missed one.
68 build thread
Old 02-23-2005, 02:33 AM   #4
RON WOODGEARD
Resident Young Old Dude !
How long ago did you change your intake????
RON WOODGEARD is offline   Reply With Quote
Old 02-23-2005, 02:41 AM   #5
skokie
skokie's Avatar
I belive it was end of last summer.
68 build thread
Old 02-23-2005, 02:47 AM   #6
RON WOODGEARD
By any chance was it after that, that you noticed the vibrations?????
Old 02-23-2005, 02:49 AM   #7
skokie
skokie's Avatar
Good question Ron. I honeslty couldnt tell you.
68 build thread
Old 02-23-2005, 02:59 AM   #8
RON WOODGEARD
OK,,,, if you were to be getting a Lean Air fuel ratio at a certain RPM, that could be causing the Vibration you are describing.... especially if it were to only be in one cylinder... So in other words..... It's a Possibility, that the intake gasket either slipped, or folded when you installed the intake.. Causing one cylinder to suck air, and causing a vibration, and Causing the oil to work up the threads...
If the gasket is leaking from the outside of the engine, You can take a can of starting fluid and spray right at that area.. If you have a leak, the rpms will increase. But if it's folded, broke, or slipped on the Engine valley side it will not make a difference.. Then it's the Find out the hard way,,, !!!!!
Old 02-23-2005, 03:11 AM   #9
skokie
skokie's Avatar
Ron I am almoste afraid to ask what the " hard way is" if its taking off the intake then thats ok because I want to get a oil filler hole machined into my edelbrock 2101. If not then I may be getting over my head but hey thats not the first time for that and the guys up on this board have talked me through many a things
68 build thread
Old 02-23-2005, 03:32 AM   #10
RON WOODGEARD
Yes,, That's the hard way.... Pull it off good and slow so as not to comprmise what's done to the Gasket, if anything is....... If it's flat and well seated,, Then it's back to square one on your problem......
When I install a new intake gasket, I use gasket sealer on the block side of the gasket, then run a bead of silicone on the front and rear of the block to seal the ends. I let the gasket sealer completely cure before I set the intake on, and allow the silicone to set up to a tacky texture....
I use The "Copper" stuff for sealer.. ( forgot the name....)
