Professional Grade
Body Mount Bushings?
What type should I get and where should I get them? I need the two front clip bushings and the four cab bushings
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
OutOfMyMind & I'llNeverKnowWhy
I need them too. I think rubber would be the best for a soft ride. Poly I hear is harsh. So far I've found LMC Trucks to carry them.
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page ![]() I don't like to save, it's more fun to spend!! |
i bought thr polyurethane ones from LMC for my GMC 76 K15 4X4.
I love them what a diff from the pieces of tire that was stacked up holding my cab. it came with the rad support bushings and the cab ones. They are great truck rides great
Tony ![]() "Life is a Team Sport" To the memory of the Hendrick Motorsports Plane Crash Victims |
I bought the rubber cushion kit from LMC. It comes with all bolts and washers. I did this when I swapped cabs on my C20. I had one cab bolt that really was in there! I had to soak it for a while and use a cheeter pipe to get it loose. The ride is good, but it's still a C20. I also put a thin strip of rubber between the bed and frame where the bed bolts mount. I'm hopeing that will kill any squeaks. David
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed ![]() ![]() |
#5 | |
Professional Grade
Is there any major difference between a 2wd and 4wd's body mounts, or is the difference just between the years? There is a kit on Ebay for a 2wd half ton, but these are for a 3/4 ton 4x4.
Parts Source has them I believe. They are a division of Cdn Tire so should be out your way.
If not Cross Canada parts have them. About $49.00 each if I remember right. www.crosscanadaparts.com Doug |
Professional Grade
I thought about cross canada too, but I can hardly justify spending 50 bucks a bushing when I can get an entire kit for 100 bucks US
buy poly, like 50.00 at summit racing.
54 bucks on sale at Summit. They are Energy Suspension Products. I used the exact same kit I love em. Only I paid 90 bucks to LMC 6 months ago!!!
U wont be sorry!!
Professional Grade
Alright, the summit option is looking good. I cannot tell, but does the kit include the bushings I need for the rad support?
http://store.summitracing.com/partde...=KeywordSearch
yes it does.
#13 |
Right turn Clyde
What all does it really come with? I dont see the top mounts pictured with the bottom mounts.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#14 |
u will get the rad support spacers, and all the cab mounts The new hardware is for the rear of the cab monts. U will need to cut off the steel spacer that is in the originals and reuse them. The directions will be in there. It is real easy to figure out what is what with the manual. Let me see if I can find the manual online. That would really help to explain
#15 |
Professional Grade
Hmm, I guess I am going to have to go garbage picking then, I tossed all the old mounts yesterday :P
