Old 02-23-2005, 05:08 AM   #1
tnblazerk5
User #12137
tnblazerk5's Avatar
help with c30
i got a 69 c30 and dont know what to do with it yet
how can i tell what gear is in the rearend of it or do i have to take the cover off to see ?
how hard will it be to make a 4x4 out of it ?
i have got a tranny and xfer case and a 8 lug 10 bolt for the front end out of a 77 3/4 ton truck can i take the spring purches of the 77 and put them on the 69 ?
do i need to use the 14 bolt rear out of the 77 too ?if so where can i get a duelly conversion kit for it ?
tnblazerk5 is offline   Reply With Quote
Old 02-23-2005, 06:06 PM   #2
tnblazerk5
User #12137
tnblazerk5's Avatar
anybody ?
Old 02-23-2005, 06:34 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
is it a daully c30? probably has 5.14 gears. You could jack up one tire and rotate the wheel twice and count the number of times the driveshaft turns, little over 5=5.14 right at 4.5=4.57 or just over 4= 4.10.
yukon jack has a buddy that has converted a 2wd C30 to a 4wd. PM him.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-23-2005, 06:39 PM   #4
tnblazerk5
User #12137
tnblazerk5's Avatar
i will get pics as soon as the batterys charge
and i dont think the rear is factory from the looks of the rear of the frame it was a dump truck at one time
and thanks i will pm him
Old 02-23-2005, 07:58 PM   #5
1969 GMC
1969 GMC's Avatar
if the rear axle isnt too rusty, the gear ratio might be stamped on the outside of the third member. both of the third members I have are this way.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-23-2005, 08:03 PM   #6
tnblazerk5
User #12137
tnblazerk5's Avatar
ok i will look when i get the pics ,thanks
Old 02-23-2005, 08:15 PM   #7
67_C-30
I have a radical idea!
67_C-30's Avatar
You could give it to me!! - j/k. I'm building a dually out of mine. Here are a few threads that may give you ideas!
http://67-72chevytrucks.com/vboard/s....php3?t=140970
http://67-72chevytrucks.com/vboard/s....php3?t=126946
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 02-24-2005, 06:24 AM   #8
tnblazerk5
User #12137
tnblazerk5's Avatar
give it to you sorry i just got it and have been wanting a 1 ton for a long long time now i got one ,,,,,,,,well part of one anyway so far its a rolling frame with a flatbed on it and i want to make a 4 wheel drive out of it like the one yukon jack's buddy has but with a 67 cab and front clip on it
Old 02-24-2005, 07:18 AM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've got a couple of duallys.
They usually have some sick ratio in the rearend like 4.56 or 5...something. What I did was to pull a center section out of a 3/4 ton rearend and put it in. That got me a 4.10 ratio, which isn't great, but better.
The centersection swap is dead easy. Just unbolt the axles and pull them out a few inches, then unbolt the center section. It will drop onto the ground.
The dually has an HO72 rearend and the 3/4 ton has an HO52 rearend. But, the centers swap directly without mods. The HO72 dually rearend is hypothetically somewhat stronger, but it's splitting hairs in my opinion.
Old 02-24-2005, 07:26 AM   #10
tnblazerk5
User #12137
tnblazerk5's Avatar
this rear looks alot bigger than a HO72/52 to me, it looks like what ya find under dumptrucks or school buses as soon as i get new batterys for the camera i will get pics of it ( the rechargeable ones died )
Old 02-24-2005, 09:00 AM   #11
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Is the cover removable? If not its a H110. the no-spin is still available for it.
Old 02-27-2005, 03:52 PM   #12
tnblazerk5
User #12137
tnblazerk5's Avatar
ok i got batterys for the camera and heres pics of the rear end . what is it ?
wheels
rear end
Old 02-27-2005, 04:02 PM   #13
1969 GMC
1969 GMC's Avatar
yup, thats the H110. it was an optional rear axle for the C30 series. 11,000# capacity 12.25" ring gear...its a big'un.
1969 GMC K2500
1996 Honda Accord
Old 02-27-2005, 04:05 PM   #14
67_C-30
67_C-30's Avatar
Wow! I didn't know you could get a 1 ton with that rearend. What size rims does truck have??
My trucks
Old 02-27-2005, 04:06 PM   #15
tnblazerk5
User #12137
tnblazerk5's Avatar
can a 78 4x4 front end be used under the a 2 wheel drive 69 c30 if i use the 4x4 front springes and purches from the 78 ? anybody did this ?
69 front end
78 front end
78 front spring rear mount
78 front spring front mount
Old 02-27-2005, 04:07 PM   #16
tnblazerk5
User #12137
tnblazerk5's Avatar
18 inch split rims and they got to go lol
Old 02-27-2005, 04:09 PM   #17
67_C-30
67_C-30's Avatar
Are you going to put a bed on it, or leave it as a flatbed?
My trucks
Old 02-27-2005, 04:09 PM   #18
tnblazerk5
User #12137
tnblazerk5's Avatar
ok thanks at least i know what it is now so i can look for the gear ratio on the stump sumwhere then ?
Old 02-27-2005, 04:10 PM   #19
tnblazerk5
User #12137
tnblazerk5's Avatar
flat i am also goin to add a goose neck hitch to it !!!!!
Old 02-27-2005, 04:12 PM   #20
67_C-30
67_C-30's Avatar
If you are going to leave it flatbed, I have a '66 3/4 ton 4X4 that you could put your body on. It already has a 14 bolt rear and D44 frontend. It has a 305V6 with a SM420 4 speed.
My trucks
Old 02-27-2005, 04:19 PM   #21
tnblazerk5
User #12137
tnblazerk5's Avatar
what ya wantin for it ? how would i get it to here ?
Old 02-27-2005, 06:54 PM   #22
67_C-30
67_C-30's Avatar
I was hoping to get $800 out if it since the old V6 runs so good. I know it will part for more, but I'd like tro see somebody be able to use it as is. I could possibly deliver it since your in TN. Also, if you are still looking for a 4 speed bell housing, I can put one on your door step for $50. I get a great rate on shipping and you are close.
My trucks
Old 02-27-2005, 07:03 PM   #23
tnblazerk5
User #12137
tnblazerk5's Avatar
i will have to think on that and i really dont need the motor but i may be interested in the bell housing
Old 02-27-2005, 07:58 PM   #24
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Probably has 5.13 gears. The no-spin is still available for that rear also.
Old 02-27-2005, 08:08 PM   #25
tnblazerk5
User #12137
tnblazerk5's Avatar
ok but where would i find a front gear to match it at will that low of a gear even fit in the front housing i got ? i really want it to be a 4x4 i kinda need 4x4 around here with all the hills and wet weather
