Old 02-23-2005, 05:47 PM   #1
smokekiki
Mike
smokekiki's Avatar
Tilt colum adjustment.
I am putting a new turnsingal handle on my colum next week,it is from Ron Francis and has a push button on the end to replace my dimmer switch.My tilt is a little loose.How do I adjust/repair it while it is apart?It is a van colum.I am putting the dimmer on the colum because I am one-legged.Now that I ran new wires and relays to the headlights,I can't leave them on high.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 02-23-2005, 06:14 PM   #2
JimKshortstep4x4
Smile
From my experience the looseness is probably in the screws that hold the support to the column as they can loosen up. It is either the screws are loose or the shoes and/or pins that the shoes ride on. I have never seen the trunions wear enough to cause a problem.
If you don't have the schematic, I will be glad to fax you one.
Jim
Old 02-23-2005, 07:19 PM   #3
Bob Moore
Some slop can be cured by adjusting the nut below the spring and canel cam.
I just did one with the turn signal in place but it would be easier without the turn signal switch in the way. The threads are fine thread. I used a small needle nose vice grip as I did not have an extra deep socket.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
