Old 02-23-2005, 07:18 PM   #1
1974gmc
In Progress
1974gmc's Avatar
Question brake help please
the rear brakes on my 74 gmc 1/2t have been starting to squeel so i checked them out the other day and they look nasty. the pads or worn so they need replacing... on the pass side the inside surface on the drum is rusted so it looks like it hasnt been workin?? and everything was covered in fluid... im guessing axle seals or maybe wheel cylinder?? anyone have any ideas?
1974gmc is offline   Reply With Quote
Old 02-23-2005, 09:16 PM   #2
60-66 Nut
Professional Beer Tester
It's usually pretty easy to tell, brake fluid will wash clean with water, but water won't even fase gear oil. If the drum is rusted, chances are the cylinders are stuck and/or leaking.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 02-23-2005, 10:14 PM   #3
1974gmc
In Progress
1974gmc's Avatar
i checked the fluid level in the master cylinder and its down a bit? what all else should i replace when doing them?
Old 02-23-2005, 10:49 PM   #4
60-66 Nut
I always replace the wheel cylinders when I replace brake shoes, because even if they're not leaking yet, sometimes they will after you disturb them, and they're not that expensive anyway. As for the master cylinder, if it's not leaking or by-passing(pedal will ooze down sometimes) then it should be OK. Check your drums for excessive wear or cracks, and make sure your springs and hardware are in good condition. When replacing the shoes, if the lining on two of the shoes is thicker or longer than the other two, put those to the rear.
60-66 Nut
85 GMC Short Bed
86 GMC Short Bed
92 GMC 1500
