Old 02-23-2005, 09:34 PM   #1
67mbsc
How do we get 5 lugs for rear?
Hey Yall,
I have a donor '86 for the front suspension, brakes, etc., but what has been done to get the rear axle to 5 lugs, short of clipping the trailing arm brackets? Are there any other rears that the axles will swap? ANy ideas or info will be REALLY appreciated.
67mbsc is offline   Reply With Quote
Old 02-23-2005, 09:45 PM   #2
cdowns
cdowns's Avatar
71-72 rears will bolt right in
Old 02-23-2005, 09:48 PM   #3
neonlarry
neonlarry's Avatar
Have the axles and drums redrilled for 5 lug.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 02-23-2005, 11:32 PM   #4
raggedjim
raggedjim's Avatar
I've done it both ways but changing in the whole rearend from a 71-72 chevy truck is easiest, unless you are a machinist...
Rg
raggedjim is offline   Reply With Quote
Old 02-24-2005, 12:44 AM   #5
tom hand
CCRider
tom hand's Avatar
Chevy duty has a kit that you can use to "bolt in" the 86 rear end (requires welding)... Part # 93-313
http://www.chevyduty.com
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 02-24-2005, 01:40 AM   #6
67mbsc
Thanks for the posts, I'll probably go with the "bolt-on" kit, to save my 67 rear from getting chopped up. Thanks Again
Old 02-24-2005, 04:00 AM   #7
inline6Bill
A classic GM kinda guy
Check with either Early Classic Enterprises or Classic Performance Products for 5 bolt axle conversions. Here are their web addresses:
www.earlyclassic.com
www.classicperform.com
Old school rap music: a dual exhausted GM 6 with no mufflers.
"If you can find a better vehicle, buy it" Lee Iacocca, Chrysler commercials of the '80s.
"I did. They are called Classic GM pickups !!!"
inline6Bill is offline   Reply With Quote
Old 02-24-2005, 04:05 AM   #8
68C15
blood type; Retumbo
68C15's Avatar
what I have is a 70 coil sprung rear under my 68 GMC. then I swapped the axles from a 80 donor truck. this also required the use of the 80 brakes to go with the later drums. it all bolted righ up with no problems.
I hope this helps
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
