Old 02-23-2005, 11:50 PM   #1
cliffsta
Stepsides RULE
cliffsta's Avatar
Idle screws on a 2 barrel
Well ever since we did the timing set, the carburetor's idle has been WAAAYY high. I know my couisn f'ed with the screw that is on top(?) that you can only get to with the air cleaner off. The other one that is on the throttle is prob wachk too. I know the timing is right (around 8 or 9 BTDC) at the right RPM idle.
It idles about where it should in drive, but when in park or neutral (when its on the high idle screw) its waaay TOO HIGH. As in, if you cut it off without bumping the throttle to get it off that high idle, it knocks LIKE A BEAST from being revved soo high, and the moment turns it over a few more times. Yeah, i know, major looseness of the motor. What ya expect, its got somewheres around 160G, the supposed end of the life of a 305.
So if i play with that screw on top (?) of the carburetor, can i get the high idle to be lower, and the idle in gear to be about the same?
This is the OE Rochester DualJet 2 barrel on my 1980 305.
thanks guys
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 02-25-2005, 05:08 PM   #2
cliffsta
Stepsides RULE
cliffsta's Avatar
Wow, no ideas?
Old 02-26-2005, 11:49 AM   #3
TrainD5115
North Coast, baby!
TrainD5115's Avatar
There are two options that I see from my exploded view of a dualjet. You have the fast idle screw on the right side which contacts the fast idle cam during warm up. On the left side you have idle stop screw near the idle speed solenoid.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
