Old 02-24-2005, 02:10 AM   #1
dalbers
dalbers's Avatar
tilt?
Can I use the tilt column off an 85?
dalbers is offline   Reply With Quote
Old 02-24-2005, 02:18 AM   #2
dalbers
dalbers's Avatar
and maybe the power steering stuff?
Old 02-24-2005, 02:47 AM   #3
71swb4x4
71swb4x4's Avatar
The 85 has the ignition on the column, so it would take a lot of work.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-24-2005, 04:25 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
sure, just remove the ignition switch, dimmer switch, & the welded on bosses that these bolt to along with removing the mounting bracket bosses. then on your truck remove the protrusion which located the factory column under the cluster. if you dont believe me I can post pics, just looks gaudy having the lock cylinder sticking out the side. but what the hey, at least I have a cheap tilt!
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 02-24-2005, 04:28 AM   #5
useRc10
useRc10's Avatar
van tilt would probably be easier...and pretty cheap in the yards
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 02-24-2005, 06:56 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
evenbetter buy the one from 71swb4x4
Old 02-24-2005, 08:04 AM   #7
MOTHERTRUCKERS
I have one from a 73 and newer truck but lost the key 50.00 + ship.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
