#1 | |
Can I fix this bar, and the install the plastic cover without pulling the steering wheel and all of that mess? Thanks a lot. Gil.
1986 Silverado Short Bed Reg Cab 305 Automatic |
Okay, need some help with the gear indicator ...
I just finished swapping out the column on my 86 Silverado. I've got everything together but the indicator that tells you if it's in park, drive, etc. is helplessly just sitting there.
There is a spring the helps it pull itself back to park, but the problem is when you are putting it in gear it doesn't pull the other way. There is a small wire and a clip at the end of it. Obviously the clip must clip onto something that pulls it in the direction of drive, and then the spring puts it back in the park position. What does the clip clip onto????????? ![]() A pic would be great, but that's probably asking a little too much. Thanks a lot for your help. Gil.
Pick up man
thats probbably broken as they are known to do so yea if u dont see the little clip on the orange ondicater then its prolly broke
cb
heres sum pics of my truck ![]() heres my baby 1990 k1500 ![]() ![]() check out this 1957 chevrolet for sale |
What can I do next ????
clip
hey man the clip fits onto the slider tube ( the parts that the shifter is attached to) it fits on the end just under the plastic cover below the column. note that the clip is going to have to be closer to the right side of the tube so when you pull the shifter down it will pull the string. the best thing to do is put it on while in park so you wont pull it to far and break it. no screws hold it in place so just kinda slip it onto the tube.
