Old 02-24-2005, 01:17 AM   #1
bigbluthng
bigbluthng's Avatar
96-98 chevy/gmc trucks and 96-99 full size vans have the vortec engine. i have heard to get the 062 casting heads rather than the 906 castings because the 906s don't flow as well on the exhaust side. i know a guy that does cylinder head porting and said it's boloney.check out recyler.com for local deals. most of the intake gasket failures are related to overheating.
you probably already know a properly tuned q jet will perform like fuel injection; smooth and reliable with great economy. if you really plan on keeping the 350 trans, consider swapping out the gears in your rear to some numerically lower.
bigbluthng is offline   Reply With Quote
Old 02-24-2005, 03:47 AM   #2
Tim240Z
Tim240Z's Avatar
96+ Vortec 5.7 in my 71 Cheyenne
For various reasons (which I won't bother going in to), I need to convert my truck to squeeze as much fuel mileage out my truck as possible.
I am currently running a rebuilt (by me) 350 with vortec heads and L98 Vette cam grind and RPM performer intake and 750DP, and TH350.
I've considered just putting in a OD tranny, but after much soul searching, I've decided to transplant with a 5.7 Vortec out of a 96+ chevy truck or sub.
I've searched through pages and pages here and found a little info, but nothing really substantial.
I have no problem with the conversion, it should be as close to bolt on as can be (done an LT1/T56 in my 240Z , as well as many other conversions).
What I am looking for is info on any particular issues with engines that I should look for....reliability issues (I saw something about intake gaskets), any idiocincracies with the engine/tranny that I should be on the lookout for.
Thanks,
1972 Suburban C20
454/TH700R4, eaton-corporate 4.10 (looking for 3.7)
Sold: 71 Cheyenne 20
Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005)
Tim240Z is offline   Reply With Quote
Old 02-24-2005, 04:26 AM   #3
Leinie
If your replacement engine had orange antifreeze in it- replace all the gaskets that contacted that crap.
How much MPG increase do you expect to get ?
Leinie is offline   Reply With Quote
Old 02-24-2005, 04:34 AM   #4
Tim240Z
Tim240Z's Avatar
Right now I get about 10 with a tailwind....hoping for 15-18 on the freeway.
1972 Suburban C20
Old 02-24-2005, 04:58 AM   #5
incoma
incoma's Avatar
I've head of 20+ with a newer model fuel injected engine (LS1 style) and a 4L60E transmission properly tuned.
incoma is offline   Reply With Quote
