Old 02-24-2005, 07:36 AM   #1
1969K10
1969K10's Avatar
How a Rockwell works
So, I blew out a U-joint, and Tuesday after work, I found it. Unbolted the rear drive shaft, to get to work Wed. morning... Anyway, when I was replacing the U-joint, I still had the X-fer in gear & the hubs locked. So I reached up, and slipped the X-fer into neutral. Well, the front & rear driveshafts were still connected. This caught me off guard I ended up unlocking the front hubs (2-HI would have worked).
So this got me to thinking what are the "main" differences between the Rockwell, and a New Process. If I recall, I have straight cut gears, what about the NP?, and the neutral thing...
Just wondering for my own general info...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 02-24-2005, 08:55 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
The new process gears are helical.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-24-2005, 06:58 PM   #3
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
When you have the t-case in neutral, both output shafts are still coupled. The t-case gears are uncoupled from the trans. output shaft.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 02-26-2005, 09:00 AM   #4
1969K10
1969K10's Avatar
Cool, thanks y'all!
