Old 02-24-2005, 12:11 PM   #1
OldJimmy57
Any of you guys running fuel injection?
I need a tank to go between the rails of a 68 frame. The motor I am using is a 98 LS1 and I need a fuel injected fuel pump and tank. Any ideas?
OldJimmy57 is offline   Reply With Quote
Old 02-24-2005, 12:37 PM   #2
67chevemall
67chevemall's Avatar
Get a fuel cell with electric pump, regulator, and filter!
0.02
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-24-2005, 02:51 PM   #3
71RestoRod
71RestoRod's Avatar
I wanted an in-tank solution for my EFI also. When I purchased a new stock steel tank for my Blazer I had it shipped to Rock Valley in Illinois. They did a great job modifying the tank to accept an in-tank Walbro fuel pump. That was a cheaper route for me than the SS tanks you can get at EC, Brothers, etc...
71RestoRod is offline   Reply With Quote
Old 02-24-2005, 03:30 PM   #4
GreyHoundSteve
you should pm fcg, ive heard nothing but good things about his tanks.
GreyHoundSteve is offline   Reply With Quote
Old 02-24-2005, 03:42 PM   #5
smokekiki
Mike
smokekiki's Avatar
Check this link http://www.thedetailzone.com/Tanks%2...%20Install.htm There is a link in the article for the unit
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 02-24-2005, 03:44 PM   #6
smokekiki
Mike
smokekiki's Avatar
It is an in tank unit that is adjustable for depth and has a "baffle" to keep the pump fed.
Old 02-24-2005, 04:01 PM   #7
71RestoRod
71RestoRod's Avatar
yup, smokekiki... that's essentially the same unit I'm running w/ baffle... I had remembered seeing the Tanks Inc unit somewhere in one of my street rod magazines. When it finally came time to install... I couldn't find it so I decided to let Rock Valley install their version.
Old 02-24-2005, 06:41 PM   #8
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
the tanks out of 88-91 blazers will fit just need a few mods to your frame xmembers these are efi tanks and can use stock in tank pumps from tpi cars.
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 02-24-2005, 08:05 PM   #9
jtmiller92
What kind of frame xmember mods do you have to make, a local guy near me is parting out an 89 Blazer..............jt
2011 Camaro 1SS LS3/6 Speed
jtmiller92 is offline   Reply With Quote
Old 02-24-2005, 09:17 PM   #10
sixty8c10
sixty8c10's Avatar
look here http://www.geocities.com/cst68chevy/ , this is a board members truck (not mine) he used a pretty good idea i think.
Old 02-25-2005, 01:10 AM   #11
71swb4x4
71swb4x4's Avatar
I had a tank built by fuelcellguy. I am running TPI, awesome tank. Cuuldn't be happier.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-25-2005, 04:54 AM   #12
68LSS1
68LSS1's Avatar
Keep in mind a TPI or typical fuel injection pump will not supply enough pressure for a LS1. It will have to be a stock pump meant for a LS1 or a aftermarket unit.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 02-25-2005, 09:01 AM   #13
NPilot1975
NPilot1975's Avatar
Try Rock Valley Antique Auto Parts. They built my tank out of stainless steel with the TPI pump in the tank. I am running an LT-1 and getting ready to build a truck with a LS1 and plan to use them again.
http://rockvalleyantiqueautoparts.com/
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 02-25-2005, 09:43 AM   #14
Wootdog
Wootdog's Avatar
Rock Valley
Is the route I went also. It works great. But due to price, If I had to do it again, I would use fuel cell guy. I have heard only good things about him. My two cents, Kerry (LT1 in a 67 C10)
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 02-25-2005, 09:44 AM   #15
71swb4x4
71swb4x4's Avatar
The pump insert in my tank is the TPI insert. The company makes all sorts, PM fuelcellguy, he can tell you for sure, but I am pretty sure he can set them up for an LS1.
Old 02-26-2005, 09:20 AM   #16
69Custom
69Custom's Avatar
Here is a link that someone posted that they put a new style camaro tank for the ls1 for his conversion.
http://67-72chevytrucks.com/vboard/s...ht=camaro+tank
I used a blazer tank and aeromotive inline pump.
Good luck
1972 Chevy C-10 Short Stepside
6Cyl, 3 spd, not opts
(Current Project)
Now a 2004 SSR 5.3L with 4L60E
Now Ididit tilt- ps, pb
2002 Saturn L200
2006 Toyota Highlander HYBRID
69Custom is offline   Reply With Quote
