72GMC51
Lower radiator hose
Any one have the GM Performance parts serpintine system (or any stock GM serp system) if you do what lower Rad hose do you run, the stock one just won't make the curve and I tring to stay away from a flex hose. My truck is a 1972 GMC 1/2t 2wd 350 Auto a/c
72 GMC 2wd 1/2 long 350 700r4 A/C PS PB 4:10. Are they ever really finished ![]() Last edited by 72GMC51; 02-24-2005 at 12:41 PM. |
Cantankerous Geezer
I assume you're running the long pump. I don't have the serp, but was able to make a Dayco 70664 work with the long pump.
http://207.44.196.117/vboard/showthread.php3?t=138379
Fred There is no such thing as too much cam...just not enough engine. ![]() |
72GMC51
The problem is the alum bracket for the a/c pump and air pump, cant make the corner around it and the frame, it is alot lower.
72 GMC 2wd 1/2 long 350 700r4 A/C PS PB 4:10. Are they ever really finished ![]() |
Is the belt rubbing on the hose in that pic above?
Maybe you'll have to make a steel extension or such?
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
72GMC51
No the belt doesn't rub there is plenty of room between the belt and hose its the bend thats the problem. I guess probably have a solid pipe made and use straight rad hoses to connect, unless someone else has any other ideas.
![]() Join Date: May 2002
72--I can't help you with the hose, but I have a question? I'm considering a serpentine setup and I'm wondering if your setup came with that idler in place of the air pump? Or is that something you made yourself? Thanks!
Stepsides look like real trucks! Smitty ![]() |
Had the same problem with my 71, but don't have the serpentine belt. If I remember correctly, think I used a hose made for the 72 Blazer which has the long pump. It has a sharp bend up at the water pump end. Fits perfectly on my truck. May be able to find the part number if you need it.
#8 | |
72GMC51
I wish I could help with the hose issue, but if you do find a hose that fits please post the part # or application of the hose because I was considering this very same setup.
Also, I noticed that you have a sanden A/C compressor mounted in place of the radial unit thats supposed to go there, what did you do to make it fit?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#10 | |
72GMC51
Thanks, I already have a Vintage Air system installed on my truck with a V-belt bracket. I wanted to put the serpentine system on there but I was thinking that I would have to use the radial compressor with the hose adapter kit to make it work.
I hope you figure out the hose thing, it looks like you're coming together there.
#12 | |
72GMC51
Thanks JC
#13 |
72GMC51
Finally have the solution I hope, had a piece of pipe bent and used parts of a stock replacement hose. Will have it made in Stainless tomorrow with a mandrel pipe bender, and hope for the best.
#14 |
Nice Job!
#15 |
Got Light Emitting Diode?
nice valve covers
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
